worked on my car some today.....
Old October 29th, 2005, 09:59 PM   #1
1985 Mustang GT
14.72 @ 93.84
matt0114 is on a distinguished road
replaced radiater hoses, battery cables, changed oil, put in new spark plugs and wires.....and it crunk up on the first try....i'm so happy. its sat up for close to 8/9 months probly. a few questions though....
1. when its running ( i only ran it for about 3-4 minutes cause it was dark and cold outside) it blows alot of white smoke. and makes the entire yard smell like gas.
2. it has a real rough idle..
3. somewhere in the engine compartmant someting sounds like a shop vac is on, either sucking or blowing air really fast and loud.
what yall think?
Old October 30th, 2005, 04:51 AM   #2
redsMULLT1's Avatar
93 GT
redsMULLT1 is on a distinguished road
Sounds like a good ol' vacuum leak to me. Check ALL your vacuum hoses and fittings. It could be a PITA.
Old October 30th, 2005, 12:15 PM   #3
1985 Mustang GT
14.72 @ 93.84
damnit....ok i'll go check em..... so a vaccum leak could cause the white smoke??
Old October 30th, 2005, 01:33 PM   #4
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
Yeah, because what its doing is allowing the car to run rich. Not good for the new plugs either. The white smoke is fuel smoke.
Old October 30th, 2005, 01:49 PM   #5
IcantDo55 is on a distinguished road
Smoke might just be condensation in the exhaust and oil, it hasto get to operating temp for a while to evaprerate that out. The blow or suck noise could be a vacuum hose but 5.0's uasually don't just drop hoses so I'm betting on a leak from the smog pump (if you still have one).
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old October 31st, 2005, 11:47 AM   #6
1985 Mustang GT
14.72 @ 93.84
no smog pump on car, there were a couple of hoses that used to go somewhere but were plugged?? i'll take a few pics, one of them was dryrotted, so im sure a vaccum hose has just fallen off then maybe. i dunno....
Old May 11th, 2007, 03:04 PM   #7
NoPHONYpony is on a distinguished road
see if u could get the car to run up to operating temp to burn off if any water vapor inside thats what usually cause that especially when its cold out also thats a vaccum leak it will cause it to loose air so the comp will let up on the fuel which makes it run lean like that
Old May 11th, 2007, 04:40 PM   #8
g money is on a distinguished road
This post is a year and a half old.
Old May 11th, 2007, 11:50 PM   #9
Stangzilla's Avatar
Stangzilla is on a distinguished road
Damn Newbies dont read!!!!
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old May 11th, 2007, 11:55 PM   #10
neverfastenough's Avatar
neverfastenough is on a distinguished road
You think he's still trying to fix it?
9000 hp, 170 knots, 9 aluminum drive shafts, 3 piston disk brakes, can carry 9 camaros to the junkyard at the same time.
Threads Similar to: worked on my car some today.....
saw two 5.0's today nba1341 5.0 Mustangs 0 June 12th, 2007 09:23 PM
got my new toy today.. dice 5.0 Mustangs 11 April 30th, 2007 11:28 AM
So I've had a rental while my s197 is being worked on. L33T The Clubhouse 8 June 15th, 2006 11:50 AM
Worked on the elty juan today redsMULLT1 All Other Vehicles 3 March 18th, 2006 12:09 PM
Some of the site updates I worked on today mdvaldosta The Clubhouse 8 August 24th, 2005 10:03 AM
