Discussing Tranny Swap Question in the 5.0 Mustangs Forum. I have a buddy who wants to take the auto out of his 5.0 ...
Old April 8th, 2008, 08:06 PM   #1
I have a buddy who wants to take the auto out of his 5.0 LX and put a t5 from a 4-banger in...we were wondering if the driveshafts where the same on the 2?
Old April 8th, 2008, 09:19 PM   #2
1993 mustang lx convertib
you can measure the shafts when there out if they are the same legth use the one thats in better shape if not use the one that came out of the v8 it will be the proper length
Old April 8th, 2008, 09:21 PM   #3
e3sean's Avatar
i am having a problem with that the input shaft is longet on the 4 cylender and thinner pilot bearing shaft. i have not found out which pilot bearing is needed so i am just going to sell it to someone else. but if u could find thr right pilot bearing and shave the tip of the input shaft down it should work fine. if u dont it will put a heavy preload on the bearing and cause failure.
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331
MILITARY CREW
USAF LUKE AFB AZ,
E-4 AMMO I.Y.A.A.Y.A.S
Old April 8th, 2008, 09:23 PM   #4
e3sean's Avatar
u cannot use a shaft from a 5.0 t-5 cause the 5.0 input shaft (4th gear) is a 23 tooth and the 2.3 is a 19 or 20 tooth.
MILITARY CREW
USAF LUKE AFB AZ,
Old April 8th, 2008, 11:37 PM   #5
fastford3388's Avatar
1989 Mustang GT
14.70@99mph
yeah that just sounds like a bad idea. those t-5 s out of the 4 bangers weren't built like the ones out of the 5.0. just sounds like something would break.
- '89 Mustang GT
- '90 Mustang LX
Old April 9th, 2008, 12:21 AM   #6
True. The t-5 for the 4 banger is too weak, plus the gears are a lot different. Google history of t-5, good info.
2007 Explorer Sport Trac, 292 HP, Stock
Threads Similar to: Tranny Swap Question
tranny swap? Uncle Humjaba 5.0 Mustangs 12 January 19th, 2008 10:18 PM
Tranny swap popmyclutch V6 Mustangs 8 October 8th, 2007 01:00 AM
tranny swap question gicantor2 2005+ 5 September 3rd, 2007 12:21 PM
tranny swap 95blueGT 94-95 6 June 9th, 2007 12:52 AM
T5 To C4 Tranny Swap 88mustangowner 5.0 Mustangs 2 November 9th, 2006 10:19 AM
