2.3/EFI-to-5.0/Carb
LinkBack (2) Thread Tools
Old April 9th, 2008, 12:00 AM   2 links from elsewhere to this Post. Click to view. #1
Z28Eater is on a distinguished road
2.3/EFI-to-5.0/Carb
Hey everyone. I have an 2.3l EFI 89 LX Hatch Mustang. I'm planning on swapping the 2.3l with a 302 carburated . I'm planning on stripping everything of the 2.3l. I'm also planning on getting the 302 as a long block. I know the main necessities, but I was hoping for some advice on what I'll need to have and know. Thanks for any help.
Old April 9th, 2008, 08:06 AM   #2
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
i swapped from a 4 cyl to a windsor , it's not that hard, the hardest part ( and it's not really hard is doing the fuel system ) you'll need a bunch of little things like a throttle cable and bracket, and exhaust hangers ( i didn't have a donor car so i got mine from late model restoration 5.0 resto ) keep all your engines sensors and wiring so your guages will work
Old April 15th, 2008, 09:13 PM   #3
Can you explain the sensors and wiring that you would keep. I was thinking i could take out all the wiring under the hood since i was going carb. but now that i think of it that makes sense. What wires would i need to keep and how would i reconnect to the 302 carb.?
Old April 15th, 2008, 11:37 PM   #4
86_Notch's Avatar
1986 lx notch
9.98 @ 135
Find the computer in the passenger side kick panel , you don't need the wiring harness connected to it . find where it comes into the engine compartment thru the firewall on the passengers side, cut it off and get rid of it, The body harness is seperate and you don't need to mess with it. to run a carb all you need is a hot wire to run your igniton. It's pretty basic, i don't know much about wiring at all and i managed to do my car pretty easily
Old April 16th, 2008, 09:16 PM   #5
armalpass96 is on a distinguished road
i switched to carb on my 88 mustang and its not really too difficult...I had a EFI V8 but didn't use anything from my old car and just kept all the wiring under the hood incase i ever need to go back to efi. Just buy seperate oil pressure and water temp. I found it easier just to buy a MSD ignition.
Old April 21st, 2008, 11:01 AM   #6
I know pretty much all i need is a hot wire, but what about gauges?
Old April 21st, 2008, 11:32 AM   #7
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Most people use aftermarket gauges but the factory gauges will work as well, just need the proper sending unit for water and temp. Alt and fuel take care of themselves. Instead of "cutting" out the wiring for the EFI and engine management, just disconnect and unbolt it. It won't take much longer and someone with a 4 cyl may need it down the road. I used the throttle cable for an 85 5 speed GT when I changed mine over. Most of the wiring you actually need will still be in place once you strip out the EFI stuff. I unplugged and re-routed the headlight wiring into and behind the core support to clean up the engine compartment. I also moved the starter solenoid and asociated wiring to the other side of the inner apron which cleaned up the engine compartment even more.
Never fast enough.
Old April 21st, 2008, 01:07 PM   #8
ryans88gt's Avatar
Two links that will be super helpful
EFI to Carburetor Conversion
and
V-8 Conversion
Old April 22nd, 2008, 12:20 AM   #9
Thanks for the links. The first one helps tremendously.
Old April 22nd, 2008, 02:31 AM   #10
ryans88gt's Avatar
No problem, by the way there is a cheaper way to do the fuel. Just get a mallory or aeromotive return style regulator and plumb the efi lines the regulator near the passenger side frame rail in the engine bay. Then you can keep the EFI pump or upgrade to a larger EFI pump . Also, if you decide to go with a non-EFI style pump, remove the intank pump and you can just replace the pump with a piece of fuel hose.
Also the stock throttle cable will work just fine. If it is too long, just put a wide loop in it.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/64979-2-3-efi-5-0-carb.html
5.0L Foxbody Mustangs - myPOWERBLOCK This thread Refback March 17th, 2011 12:44 PM
5.0L Foxbody Mustangs - myPOWERBLOCK This thread Refback March 14th, 2011 09:31 PM
Threads Similar to: 2.3/EFI-to-5.0/Carb
efi or carb? 1slo5o 5.0 Mustangs 5 October 3rd, 2007 08:48 PM
FROM EFI TO CARB bluebyu 5.0 Mustangs 7 September 1st, 2007 03:28 PM
efi to carb gtstang87 5.0 Mustangs 4 June 5th, 2007 09:19 PM
carb to efi 347tt 5.0 Mustangs 5 February 11th, 2007 09:08 PM
EFI to Carb? 89fox5.0 5.0 Mustangs 4 February 8th, 2007 05:31 PM
