Modified 89
I receintly got ahold a 89 GT. It has had several owners and modifications. Someone has done some rewiring. The MAF system is gone. It has what I believe is a 351 cu. in. with 4 barrel Holley. There is a problem with the starting circuit. The starter will not crank unless, the after market oil pressure gauge impulse line is in contact with the fire wall. Also while the starter is cranking that impulse line is arcing were it is in contact with the firewall. The mainground wire from the starter relay to the engine appears to have been getting hot also, because the insulation is severlly cracked and deteriorated.After the engine starts and the starter is no longer cranking all is fine.
RLY SRS
Replace the ground that is on it now with a new and better ground and you should be all good...
Thanx. I'll try that.
Threads Similar to: Modified 89
| 400 MODIFIED | whiteboycustom | 5.0 Mustangs | 20 | September 25th, 2007 02:11 PM |
| 89' Modified SHO for DD status | ItalianBullitt754 | All Other Vehicles | 5 | July 17th, 2007 12:08 PM |
| I modified my dash, here is a pic | billyjo316 | 2005 - 2010 | 27 | January 1st, 2007 05:01 PM |
| Modified Mustang Cover Car (and inspiration to us all) | Brianzeke007 | V6 Mustangs | 14 | December 12th, 2006 10:07 PM |
| Modified Mustangs | turp | The Clubhouse | 6 | October 11th, 2005 11:56 PM |
