98 Cobra
Ring And Pinion Question
just curiouse as to what causes what
what will cause you ring and pinion to "whine" and what cases it to "knock" |
48.47@ 12.58
the whine would be bad install (shims)
the knock would probably be bad bearings or clutch packs in the diff
98 Cobra
how would bearings go bad during an install?
48.47@ 12.58
they could just be old and worn out is all.
98 Cobra
ok heres one, you know those u shaped "clamps" that you tighten down onto the bearings, theres one on each side of the carrier assembly. say if those back off, would that cause the "knock"?
48.47@ 12.58
easily.
everything in the rear end must be with in spec or it will make noise
98 Cobra
Thanx man, you've awnsered all my questions about gears lol
48.47@ 12.58
any time
Threads Similar to: Ring And Pinion Question
| Ring and Pinion Help | andres0286 | 99-04 | 4 | March 24th, 2008 03:24 PM |
| Randy's ring&pinion | tom2000r | 99-04 | 1 | March 1st, 2008 07:07 AM |
| Would you buy a used ring and pinion? | mustangmanic | 99-04 | 20 | January 28th, 2008 10:59 AM |
| Ring and pinion gear question | 06silvergt | 2005 - 2010 | 2 | September 13th, 2007 05:29 PM |
