Speaker Clicking Noise And Dash Lights Not Working
Old April 11th, 2008, 10:58 AM   #1
n/a but too much@slow
Lastofthe5.0's is on a distinguished road
Send a message via AIM to Lastofthe5.0's
hi, my speakers have recently started making a very annoying clicking noice. it started out very low but has begun to get louder. It only does it when the car is running (its perfect when the car isnt) and i might be crazy but it seems like it stops when im turning even around slight bends. oh and it also makes the noise no matter where the volume is, including muted. Thanks for any input!
oh and one more thing, lastnight i got in my car and no lights that go on when i put on the running lights would go on, just headlights, so i figured a fuse blew, found it, changed it, the lights work again, buuut all the dash lights wont go on now, so just wonderin what it could be, thanks again!
Old April 11th, 2008, 11:29 AM   #2
91cobra5.0's Avatar
98 Cobra
check your wiring for a short some were, (power thats been grounded), f you have bare wire in there swinging around and it hit metal that cold be why your fuses are poping and may evenm fix your radio
Old April 11th, 2008, 12:24 PM   #3
ok but all the fuses are good now, but the dash lights arent on, do ya think the short is in the wiring for the dashlights? and where do i even begin to check that wiring
Old April 11th, 2008, 12:43 PM   #4
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
http://www.veryuseful.com/mustang/te...nt-Cluster.gif
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old April 11th, 2008, 12:51 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
Maybe the dimmer switch? Not specific to the Mustang but those fail on a lot of cars. That may explain the blown fuse and the dash lights not working now because that dimmer is common to both. Worst case is you may have a short in the dash light area which burned up the switch and blew the fuse so just replacing the dimmer switch may not fix it and you could burn up another one, again, that is worse case. Find some wiring diagrams and track it down, without that, all we can do is guess.
Opal, your link is to a fox body diagram, is the 95 he has the same?
Old April 11th, 2008, 01:01 PM   #6
95opal's Avatar
95 opalfrost gt
My apologies Just assumed it was a fox cause of the section its in.
http://www.veryuseful.com/mustang/te...nt-cluster.gif
5.0 magazines
Threads Similar to: Speaker Clicking Noise And Dash Lights Not Working
Clicking Noise Stang187 V6 Mustangs 6 December 12th, 2007 05:17 PM
Getting a clicking noise when i get on the gas Fox2102 V6 Mustangs 33 October 22nd, 2007 12:18 AM
rubbing and clicking noise Warlord Modular Mustangs 2 January 7th, 2007 01:47 PM
Quick Help (Clicking Noise) scubasteve041186 V6 Mustangs 9 November 2nd, 2006 04:37 PM
Clicking noise 01 cobra WVSNS& 99-04 5 May 10th, 2006 08:35 PM
