24lb injectors and maf, which brand?
Old April 11th, 2008, 02:21 PM   #1
1992 Lx
11.39@119.24
im gona be upgrading my fuel system in a few weeks, im not sure which brand to use for injectors? i was thinking a pro-m maf? also i dont need a bigger fuel pump to jump from 19s to 24s do i?
Old April 11th, 2008, 02:43 PM   #2
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
try and find a 24lb meter from a cobra and some ford racing injectors they are everywhere and not that expensive
<font size=4><b>MILITARY CREW
Old April 11th, 2008, 02:56 PM   #3
e3sean's Avatar
1988 lx
9.68@142
eBay Motors: * 24LB Ford Racing Fuel Injectors Mustang FMS LT1 * (item 280216701476 end time Apr-14-08 13:58:08 PDT)
eBay Motors: Mustang C&L 73mm Mass Air Sensor (item 150235008749 end time Apr-16-08 16:12:15 PDT)
Old April 11th, 2008, 03:18 PM   #4
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
A cobra meter will do him no good as its still calibrated for 19s, while the cobra ecm makes the adjustments for the injectors.
As for injectors stick with FRPP's and for a meter I like Pro-m or the SCT meters.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old April 11th, 2008, 03:18 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Ford Racing, Holley and Lucas are some good injectors. I'd be upgrading the fuel pump before the injectors though. The stock injectors will support more than the stock fuel pump.
Old April 11th, 2008, 03:20 PM   #6
1992 Lx
11.39@119.24
i found a website that sells rebuilt injectors with all the flow tests blah blah and a 1 year warranty for 150 bucks i think ima do, as for that maf sean if you bid on that shit for me and win it ill give you the cash, thats a good deal
Old April 11th, 2008, 03:20 PM   #7
1992 Lx
11.39@119.24
oooooh i had it backwards
Old April 11th, 2008, 03:43 PM   #8
1992 Lx
11.39@119.24
well nm sean, i found that maf new, its only 130 so id rather just buy it new so for the injectors and maf its only gona be like 280 im fine with that
Old April 11th, 2008, 10:19 PM   #9
fogged306's Avatar
89 GT
+1.. I bought a Cobra MAF a couple of years ago not knowing that the calibration is in the computer not in the MAF electronics. Just wasted money.
Old April 11th, 2008, 10:34 PM   #10
90 lx notch's Avatar
1990 mustang lx notch
no track time
90 lx notch is on a distinguished road
i like the c&l maf so you just change the sample tube for larger injectors and ford injectors just my opinion
90 LX NOTCH
elec. fan, fenderwell intake, adjustable fuel reg w/ gauge, 75mm pro-m meter, 75mm ford racing tb and egr spacer, bbk pulleys & headers & offroad x-pipe, slp catback, 5 lug conversion, bullitt rims, 3.73 gears, battery relocation
Old April 11th, 2008, 11:00 PM   #11
95opal's Avatar
95 opalfrost gt
That is the sole reason i dislike them they rely on a mechanical means to offset the signal by actually changing the air volume that the electronics "see" (the sample tube).
Just not to reliable IMO.
5.0 magazines
Old April 11th, 2008, 11:14 PM   #12
fogged306's Avatar
89 GT
/\ lot of tuners I've talked to say the C&L's aren't reliable. They produce a "dirty" signal thats tough to work with. The more guys I talk to who know what they're doing with an EEC, the more I hear about using P-MASS/Pro-M.
Old April 11th, 2008, 11:27 PM   #13
1993 mustang lx convertib
saldoggs is on a distinguished road
if your gonna keep your car mostly stock just go with a bigger fuel pump like a 190 and get an adjustable fuel pressure regulator and fuel gauge this way you can turn up the fuel pressure and get more out of the injectors. everyone (me included)goes with bigger injectors and new meter but that just tricks the computer and the fuel and timing curve are not where they should be and you will not get as much performance out of the car
Old April 12th, 2008, 04:00 AM   #14
1992 Lx
11.39@119.24
oh gay i didnt know that about the c & l meters, i figured something was up cuz theyre like 130 brand freaken new, ghey ill just get a pro m i guess
Old April 12th, 2008, 02:46 PM   #15
e3sean's Avatar
1988 lx
9.68@142
the c&l housings are fine as long as u use your stock sensor in it.
during the tune they can calibrate your computer (via chip) for 24lb injectors
Threads Similar to: 24lb injectors and maf, which brand?
24lb injectors and maf 93hatch 5.0 Mustangs 3 February 18th, 2008 01:06 PM
24lb injectors? shaunnj007 99-04 10 February 12th, 2008 07:21 PM
Will Not Run On 24LB Injectors Euroeater95 94-95 5 November 4th, 2006 11:24 PM
