LinkBack (4) | Thread Tools |
#1
89 gt conv,91 gt conv
Headlight? (Stopped Working)
ok so my headlights just stoped working,the hi-beams work when you pull the turn signal switch only not when you push the turn signal switch,is there another fuse/relay pannel that im missing besides the one under the steering wheel
thanks in advance... |
1988 Mustang GT Vert
would you use your headlights and your foglights together alot??
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon... |
More than likely what he is getting at when he asked if you use your fog lights a lot, is the factory wiring melts the headlight switch when you use the lights together for long periods of time. I would check the headlight switch to see if it looks melted. If not, I would also check the mfs. TMoss has a wiring diagram that shows the upgrade to keep this from happening.
http://www.veryuseful.com/mustang/te...ights-Horn.gif
what is the mfs,i pulled the headlight plug and its definatly melted,is the switch bad or is the wiring bad....
#5 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Mustang GT Fog Light Fix
if I keep my fog lights on my headlights will flicker, I have been driving w/o fog lights for a while and it never happend again. I will do the tech above if spring ever gets here
Could be both but more than likely, it is just the switch, that is a common failure. To much current to run the headlights and fog lights and the switch overheats. Search around google or use the link above from TMOSS on how to power the foglights from a seperate circuit through a relay. There are different ways to do it but all do basically the same thing. I did mine all outside the car in the engine compartment.
i swapped the switch out with the one in my other mustang and it still does not work,the plug looks melted,so the wiring must be fryed,its weird cuz the headlight hi-beam works when you pull it but nothing else...
yes the high beams will work, its your Multi-Function Switch that melted thats the turn signal switch, you will need a new Headlight switch, and mulifunction switch, and the plug for the headlights that goes into the MFS will be melted.. just how mine was... the headlight and foglight switches have to touch each other electricity wise for them to work, soo the burnt/messed MFS switch will not return the fog light electricity to the headlights therefore no lights work besides the high beams which are compeltely different...
is there a quick fix untill the weekend besides rewiring the whole thing like the links above,i need to drive it to work @ 3am...
yes there is take it out.. the mfs switch and connect the headlight and the foglight wires together with electrical tape until you get it fixed but DO NOT turn on your foglights at all... seriously.. just your headlights
what color are the wires that i have to connect
98 Cobra
drive with just high beams, it will be a bitch but you wont risk a fire
right/black, and light green idk if thats right but try it... and see lemme know if that works...
1987 mustang 5.0 lx coupe
12.7@107
i found this thread today after my car did the same as the first poster. only i have a lx without foglights on top of that the guy that had the car before me cut off the pigtail to the headlght switch so i have bare wires just hanging out still waiting for it to burn down. so doest my car have the multifunction switch and where is it
my car did the same thing i fixed the head/foglight switch.. had to rewire all that but the headlights still didnt work i pulled the blinker switch and that was melted to... i havnt found a replacment yet but when i drive i have to hold the switch to me
brand new there $100
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
12.7@107
well i dont understand cause my wipers work my blinkers work my brights work and thats the multifunnction switch. my headlight switch only turns on the running lights so im completely lost
yeah if you pull the the whole blinker switch off youll see that its melted to if you fix that then everything should be working again
and thats just what mines doing i already rewired it so it wont happen again but i havent found the new blinker switch yet edit i didnt read your first post but it still. its probably your blinker switch
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/65746-headlight-stopped-working.html
| 91 Ford Headlight Switch Wiring Diagram - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | February 18th, 2010 03:29 PM | |
| 1988 Mustang Tach Wiring Diagram - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | February 13th, 2010 04:41 PM | |
| Ford Headlight Switch Diagram - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | December 17th, 2009 10:31 AM | |
| 91 Ford Headlight Switch Wiring Diagram - Overview : Kosmix | This thread | Refback | November 5th, 2009 03:20 PM | |
Threads Similar to: Headlight? (Stopped Working)
| Tach Stopped Working.. 87 Mustang GT | NoRegrets | 5.0 Mustangs | 2 | September 2nd, 2007 04:28 PM |
| Odometer Stopped Working | 1995svtcobra | 94-95 | 22 | July 16th, 2007 07:46 PM |
| TURN SIGNALS STOPPED WORKING!! HELP!! | 1answer | Modular Mustangs | 7 | July 8th, 2007 12:17 AM |
| My keyless entry stopped working! HELP! | alex892007 | Audio/Video | 4 | April 15th, 2007 02:49 AM |
| Got stopped by FHP | WAR-PARTY | The Clubhouse | 15 | April 14th, 2007 12:01 AM |
