BRAKE upgrade for fox?
Old April 13th, 2008, 06:51 PM   #1
blakehunter316's Avatar
1989 Mustang GT
14.01 @ 103..... :(
blakehunter316 is on a distinguished road
ok so my 89 gt dosent stop as good as my dads powerstroke dually I think I need to fix this do I needs different discs or bigger calipers maybe rear disc conversion keep in mind I just changed the pads two days ago
vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er
Old April 13th, 2008, 06:56 PM   #2
baine21225's Avatar
rear disc conversion would help
Old April 13th, 2008, 08:00 PM   #3
91cobra5.0's Avatar
98 Cobra
rear disk? dont you use like 90% front brake and only like 10% ebrake on rear?
get bigger disks and calipers in the front and ill bet u notice a difference
Old April 13th, 2008, 08:07 PM   #4
baine21225's Avatar
comparing discs and drums is like apples to oranges
Old April 13th, 2008, 09:09 PM   #5
91cobra5.0's Avatar
98 Cobra
i just mean in general, when you hit the brake dont u use like 90% front brakes?
Old April 13th, 2008, 09:59 PM   #6
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
Its more like 70-30%. And drums are fine if they are working properly. check condition of ur drums/pads and did u use ceramic pads? that could be why if u did. If u upgrade to 5 lug ull get bigger rotors/ calipers
Old April 13th, 2008, 10:00 PM   #7
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
+1
70% front 30% rear
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old April 13th, 2008, 10:01 PM   #8
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
it's like 70% I believe.........
get a strange engineering rear disc brake conversion kit. It says it will bring the stock stopping distance of 60mph-0 @ 160ft down to 130ft. It's only $380. Between that and getting some nice EBG front pads and rotors you'll be set.... That what I'm planning on doing
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old April 13th, 2008, 10:01 PM   #9
ryans88gt's Avatar
start by bleeding the brakes. If it hasn't been done in awhile, you will notice a huge difference.
Old April 14th, 2008, 05:01 PM   #10
1993 GT
13.2@105
1982matthew is on a distinguished road
what rear conversion do you guys recommend to change it to disc with 4 lug if possible.
Threads Similar to: BRAKE upgrade for fox?
Brake Upgrade! 1BADSTANG 5.0 Mustangs 10 January 16th, 2008 01:46 PM
brake upgrade fixn2 96-98 8 September 16th, 2007 08:16 PM
Cobra brake or bullit brake upgrade 97gtstang 96-98 5 May 14th, 2007 02:15 AM
Brake upgrade JBake 5.0 Mustangs 0 December 12th, 2006 02:49 PM
