Adjustable fuel pressure reg
Old April 13th, 2008, 06:55 PM   #1
5.0Madness's Avatar
1994 Mustang GT
5.0Madness is on a distinguished road
Ok heres the deal, I found a Paxton adjustable fuel pressure regulator for real cheap, and was wondering if I could see any increase in power with my practically stock GT
Mac CAI, flowmaster 40-series mufflers, Steeda shortthrow shifter, Mac O/R H-pipe
Old April 13th, 2008, 07:20 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
Well it won't hurt but I doubt you will get much out of changing the fuel pressure. You can buy new AFPR's for about $70-90 so I hope your "cheap" is a lot lower than that. I've had bad luck with new ones so I personally don't think I'd consider a used one, just my opinion though.
Old April 13th, 2008, 07:31 PM   #3
5.0Madness's Avatar
1994 Mustang GT
well for $15 I might as, Im gonna need it later on anyways, right?
Old April 13th, 2008, 09:58 PM   #4
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
yeah I really doubt you will see any increase on a stock car even thou they claim you can if tuned properly
Threads Similar to: Adjustable fuel pressure reg
How to adjust fuel pressure w/o an adjustable regulator Twist 2 Go 5.0 Mustangs 26 November 6th, 2007 09:46 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
Adjustable Fuel Pressure Regulator. MySallyMI 99-04 0 March 10th, 2007 04:31 PM
PLEASE HELP! (Adjustable Regulator Squirting Fuel) foxstang 5.0 Mustangs 10 March 2nd, 2007 07:29 PM
Adjustable fuel pressure regulator jkonfuzhon 5.0 Mustangs 12 February 22nd, 2007 03:13 PM
