Supercharger on stock bottom?
Old October 17th, 2006, 10:31 PM   #1
95StangSVT's Avatar
95StangSVT is on a distinguished road
I was wanting to put a 9 psi supercharger on my 5.0,the top ends all redone but has stock bottom.do u think it will hold up well enough?i just sold my stroker motor short block. now i want to go supercharger, just a quick low 8 sec 1/8 mile everyday driver... thanks
holley systemax upper and lowers
65mm throttle body
76mm maf
bbk cold air
24lb injecotors
e303 cam
410 gear
3core rad
bm short shifter
x-pipe
msd ignition
Old October 17th, 2006, 10:36 PM   #2
mdvaldosta's Avatar
11.47@120.58
You shouldn't have any problem as long as you keep the revs reasonable and have a safe tune.
Old October 19th, 2006, 09:34 PM   #3
1FOXBODY&1F-BODY is on a distinguished road
NOWAY YOU SHOULD HAVE ANY PROBLEMS WHATSOVER...IF YOU WANT GET A GIRDLE PUT ON WITH A WINDAGE TRAY..DSS MAKES THEM AND SELLS IT AS A KIT... ONLY IF YOU ARE WORRIED ABOUT THE BOTTOM END...BUT YOU ARE FINE....
Threads Similar to: Supercharger on stock bottom?
How Much HP On Stock Bottom End 5litercobra 2.3 Mustangs 5 November 13th, 2007 02:55 PM
Nitrous on Stock Bottom End Speedstang302 5.0 Mustangs 25 October 27th, 2007 10:15 PM
12s with stock bottom end? 95wip 94-95 8 April 16th, 2007 11:10 PM
How Much HP Can Stock GT Bottom End Take? Clutchmaster 99-04 14 March 22nd, 2007 03:58 PM
stock with supercharger 9stang1 5.0 Mustangs 2 January 4th, 2007 10:11 PM
