rear end whine
LinkBack (1) Thread Tools
Old April 15th, 2008, 11:24 PM   1 links from elsewhere to this Post. Click to view. #1
94stangGT50 is on a distinguished road
Angry
rear end whine
just replaced the stock ring gear and pinion from a 3.08 to a 3.73, never done it before but did have some instructions to follor but when i take it for a ride it whines pretty loud around 40mph was wondering what spec i might be off on?
Old April 16th, 2008, 11:03 AM   #2
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
backlash
Old April 16th, 2008, 11:05 AM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Old April 16th, 2008, 11:15 AM   #4
91cobra5.0's Avatar
98 Cobra
I did mine and it took me a few tries to get it right, mostly becuase I didn't have a dial indicator until this last try,
Did you leave the stock shim on the pinion?
Check all of your loads, make sure you crush the sleeve, get the right load on the pinion and when you shim the carrier just make sure its a tight fit to get that carrier in there, that way it loads the carrier bearings.
I know I just wrote a novel but if you got ne more questions about this just pm me, I got real good at it doin mine
Old April 16th, 2008, 11:20 AM   #5
also i should have mentioned that the gears were used out of a 98 explorer from a local auto parts store, thought ide save a little cash, but i did end up using same shims on pinion and carrier, checked backlash and it was .010-.011 i re used old bearing but got a new crush and SOB those things are hard to tighten up, how important is the drag on the pinion i know its suppose to be 16-26 or somethin in/lbs but i just kinda felt it by hand
Old April 16th, 2008, 11:42 AM   #6
91cobra5.0's Avatar
98 Cobra
Your talking about preload on the pinion? The number sounds high and yea what I did was just tourqe mine down and as I tightened it I would spin the carrier in the housing to make sure it didn't get to tight,
. You want it to spin but stop kinda firmly after like a good rotation and a half or so
Old April 16th, 2008, 07:59 PM   #7
stang fanatic's Avatar
stang fanatic is on a distinguished road
setting up used gears in a different housing typically causes the gear set to run a different wear pattern, and inevitably always make noise
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old April 17th, 2008, 01:22 AM   #8
1993 Mustang GT
13.2 @98.54
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/66309-rear-end-whine.html
rear end whine This thread Refback October 29th, 2008 02:12 PM
Threads Similar to: rear end whine
Found out what the whine was coming from the rear end... Fox2102 V6 Mustangs 7 December 7th, 2007 07:38 AM
Transmission Whine?.?.? Montanasvt 99-04 2 November 3rd, 2007 01:35 PM
knn whine? chadwick297 2005 - 2010 10 October 23rd, 2007 01:45 PM
Engine whine Tr1gger 5.0 Mustangs 12 April 19th, 2007 08:41 PM
Low Speed/RPM Whine? MSTGGT00 99-04 2 January 14th, 2007 11:49 AM
