87 Mustang GT T-top
Is there a Block that can hold more HP than the stock 5.0L out there?
I was woundering if there was any cars out there that had as stronger block than the stock 5.0's- B/c they can only hold up to 500 ( give or take some ) And i didnt wanna have to buy a new Hight Pro. Block and spend all that money if i didnt have to. So i was woundering if there was ever any blocks out there made by ford that held more than 500+ HP with no prob. What type of car and years was it?
See i was just thinking that i want just a little more HP flexibily than 500HP and figured if any of you knew of a block that was stronger that i could maybe get at a junk yard that can hold more HP and wouldnt kill me in price. Then i could just use that and bore it out/ clean it up ( obviously so i can be sure to get good compression ) I planned on having to bore it out. I think i want to do a 347 Stroker Kit. So if there is any block out there that is smaller than that ( so that i can still bore it out/ clean it up ) and will support more HP, and work/fit in my car, i was hoping you guys could tell me of some. Unless you know of some cheap slightly improved pro. capable short blocks out there. But let me know what you all think, thanks for any advice. And as always its much appreciated, thanks! - The Novice. |
1988 lx
9.68@142
the 351 will hold 700 from what i hear.. if you are going to daily drive this car 500 is alot of hp but yes the 351 is the alternitive
87 Mustang GT T-top
No def. not a DD. I live in MI so ill bearly get to drive it anyways...crummy weather. Anywho 351W eh, what cars and years did those come in, if you happen to know. Also i would have to prob bore it out like i was saying, to make sure its all clean and good to go. I dont the "est. Guideline" to how much your suppose to Bore over to "clean it up" But do they make Stokers bigger than 351? b/c if its a 351 and i have to bore it out whats a good number and/or will the block wall be too thin if i do that, i still want to be safe and not have to worry about cracking it by having too big of cylinders and too thin of wall you know?
Also i dont think that Fordstoker.com site makes any Stroker kits over a 351+. Know any who might and are trustworth and affordable? Thanks for all your help! - The Novice. |
1988 lx
9.68@142
where in michigan do u live?
87 Mustang GT T-top
Grand Rapids Area, a little North.
Big timin' in a small town
Michigan FTW
![]() Mackinaw here
89 GT
.030 over is, in my opinion, the place you want to be when you clean up the walls. If it's just normay wear and tear, .030 will be fine and you will still have good wall thickness when you're done.
If you do a 351, definitely do a stroker kit. |
#8 | |
If you do a 351 without a stroker, might as well just use a 302. |
87 Mustang GT T-top
Well i Def. want to Stroke it, And i just want the comfort of being able to have more HP with out having to worry about the block cracking. So do they make any Stroker kits for a 351+ 30 0ver somewhere along those lines? Any links by chance?
Most importantly where can i find a 351W block? What year cars had them in them that i might be able to find at a JunkYard or something? Thanks guys! |
Id just bore and stroke a 302 to 347. Well thats what im doing anyways, less weight, better weight distribution, not as much stress to the chassis. Brakes better. No cost to swap it (besides the stroker kit).
351Ws come in everything. Older 302 blocks (pre roller) handle more horsepower than the roller blocks do. Roller blocks usually can only go .030 before the cylinder walls get thin. Early blocks can go .060 and most 351W blocks at .060 are thicker than a stock 5 liter that hasn't been bored. Main webbing on th earlier 302 and 351W blocks is alot beefier as well. The main webbing is where the problems start on the roller 302 blocks. They crack right up the middle starting at the main webbing.
#12 | |
87 Mustang GT T-top
Should i be worried?Any ideas Anyone? Your right though 1badstang, will getting a 351W and making a 393 be alot more stress on my Chassis? I have welded frame connectors, but he brings up a good point, will it be too much for the chassis? Or will i be ok? Also is a 393 stroker a good idea? Any Advice anyone? Also how much HP will this make? Thanks guys, much appreciated! - The Novice. |
talk to woody, he'll hook you up
#14 | |
#15 | |
87 Mustang GT T-top
Wont there be a computer prob with a 347? or no b/c its close enough to the original size? |
87 Mustang GT T-top
Or does anyone know if them made 302 blocks start are stronger than the 5.0L ones from 87-93? Something that can hold alittle more HP, and how much more, what car years? I could just do that and bore it out to a 347.
Any thoughts or helpful info on that? Thanks. |
Either way 351 based or 302 based stroker you'll probably want a tune.
I'd go with a 408, 351 based block myself. With aluminum heads, they weigh almost exactly the same as a 302 with iron heads...so don't be concerned with weight. At the most you are talking an extra 50 lbs up front, which can be easily offset with fiberglass hood or by removing the sway bar or by replacing the K-member or by a number of other means. The 351 based stroker is much more capable (700 hp vs 500 hp), a very easy swap, and cheaper than an aftermarket 302 based block. Plus you automatically produce an extra 50-100 hp from the added 61 cubic inches (408 vs 347).
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1988 lx
9.68@142
1988 lx
9.68@142
u live in a place where there are proly more older ford parts than anywhere in the world.....
87 Mustang GT T-top
Heh ok thanks, just woundering though, if you happen to know is there a way i can know for sure by looking at if it its really a Windsor Block or not?
For Example- How the GT-40P heads have "GTP" stamped on them. Is there anything like that? Also so if i do end up doing a 393 or a 408 with EFI, The computer will be ok, it wont go crazy? But ill just need to get a good tune or maybe a dyno? Just dont want to do it if the computer is gunna cause headaches non-stop. Thanks guys for all your help, you guys have helped me a lot! Thanks guys! -The Novice. |
Threads Similar to: Is there a Block that can hold more HP than the stock 5.0L out there?
| How much power can a stock 05+ hold. | powersrj | 2005 - 2010 | 27 | May 16th, 2010 09:34 AM |
| Stock Block | GOTTORQ | 2005 - 2010 | 56 | January 11th, 2008 06:05 PM |
| stock block | Fast98stang | 96-98 | 14 | January 2nd, 2008 10:59 PM |
| how much on stock bar block | droppedbass87 | 96-98 | 1 | July 25th, 2007 09:46 PM |
| Stock Cobra Block and GT Block the same?? | bbrewer03 | 96-98 | 2 | August 26th, 2006 01:31 PM |
