How to set timing on carbed?
Old April 16th, 2008, 11:58 AM   #1
alabamastanger's Avatar
1983 Mustang GT
N/A
alabamastanger is on a distinguished road
i know that on a fuel injected, you unplug the little plug to adjust the timing, but how is it done on a carbed. I tried last night, but the timing didn't really change when I was turning the distributor. I think that I am 180 out because I am getting some backfire. Thanks,
Old April 16th, 2008, 12:11 PM   #2
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Take the vac advance hose off of the dist. and plug the end to set base timing. Did you have the dist out? I thought all you did was change the fuel filter.
Never fast enough.
Old April 16th, 2008, 12:14 PM   #3
1983 Mustang GT
N/A
That's all i did at first. I was told that the timing could be the only thing causing the backfire. I put a new Holley 650 on, but I still had the same problems. This one is supposed to have a in-line fuel filter, would this happen without that filter in?
Old April 16th, 2008, 02:06 PM   #4
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
No. The filter won't make any difference in that situation
Never fast enough.
Old April 16th, 2008, 02:23 PM   #5
ryans88gt's Avatar
^^Unless you have a lot of crap flowing through your gaslines and contaminated the needle and seat
Old April 16th, 2008, 04:07 PM   #6
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
^ Agreed. But if the float is stuck open, fuel will be pouring out of the bowl vent tubes
Never fast enough.
Old April 16th, 2008, 08:28 PM   #7
vfast will become famous soon enough
if you were 180 out it won't start..you may however be 1 tooth off....have you adjusted the bleeder screws?
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old April 16th, 2008, 08:34 PM   #8
1983 Mustang GT
N/A
How do i adjust the bleeder screws>? I don't know what/where they are.
Old April 16th, 2008, 08:39 PM   #9
1983 Mustang GT
N/A
I got to TDC (or least I think), dropped the dizzy back in, and it runs better, but it still cuts out and then starts popping (backfire?) after about a minute. Is this the carb needing adjusting, or what?
Old April 16th, 2008, 09:50 PM   #10
Jojogunne's Avatar
1984 GT
13.21@104.61
Jojogunne is on a distinguished road
If your timing is correct and it is still backfiring it might be your shooters. As soon as you touch your accelerator your shooter need to squirt fuel into the carb or you may get some backfireing.
jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over.
Old April 16th, 2008, 09:52 PM   #11
Jojogunne's Avatar
1984 GT
13.21@104.61
Also if you are one tooth off that will cause some problems too.
jjg
Old April 16th, 2008, 11:07 PM   #12
1983 Mustang GT
N/A
how do i get to not being one tooth off? just turn the dizzy a little ?
Old April 17th, 2008, 10:58 AM   #13
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
Are all of the vacuum lines connected? No vacuum leaks?
Never fast enough.
Old April 17th, 2008, 01:25 PM   #14
1983 Mustang GT
N/A
I realized that I kinked the fuel line a little when I took the fuel filter out...could this be some of my problem?
Threads Similar to: How to set timing on carbed?
5.0 EFI to 5.8 (carbed to EFI) SVT Town Car All Other Vehicles 12 July 8th, 2007 10:41 PM
im going carbed BCR93stang 5.0 Mustangs 50 July 6th, 2007 07:45 PM
carbed skid6 5.0 Mustangs 1 June 16th, 2007 07:05 PM
help with nos on a 85 carbed gt joemoto General Tech 1 January 16th, 2007 08:18 PM
Setting Distributor and Timing on a 93 5.0 that is carbed. 83 5.0 5.0 Mustangs 11 September 11th, 2006 07:57 PM
