Trans question.
Old April 16th, 2008, 01:33 PM   #1
VOLIPINO's Avatar
VOLIPINO is on a distinguished road
Trans question.
Hey guys, I am sure this has been discussed before, but I can't seem to figure out how to work the search function. Anyways, I was driving to work this morning, I had just gotten in the car, so it was cold, and the first few minutes, the trans kept popping out of gear. After it was warmed up i would be cruising around 60-65 and it popped out of 5th a couple times. Any info would be useful. Thanks guys!
"The question! Raymond! is what do you want to be?"
Old April 16th, 2008, 01:53 PM   #2
kuskye25's Avatar
kuskye25 is on a distinguished road
the guy i got a trans from im rebuilding said it had the same problem with 1st gear under load itll pop out of gear, he told me its a bad syncro.
Anyway itll need a rebuild to fix it most likely. or just dont use 5th gear for now....
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears
'93 LX 4-banger 78k miles
Old April 16th, 2008, 02:08 PM   #3
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
could be a bent fork or a badly worn gear.
it is proly poping out when u let off the throttle isnt it?
<font size=4><b>MILITARY CREW
Old April 16th, 2008, 02:17 PM   #4
kuskye25's Avatar
with a bent shift fork though wouldnt you think it would pop out of higher torque gears then 5th or does it work the other way around, and itll pop out of lower torque gears easier....
Old April 16th, 2008, 02:24 PM   #5
VOLIPINO's Avatar
Yeah, in 5th, I have an after market shifter, I am hoping it might need some adjustment.
Old April 16th, 2008, 02:31 PM   #6
ryans88gt's Avatar
Could be your shift stops are not set right. Could also be bent shift forks.
Old April 16th, 2008, 02:33 PM   #7
kuskye25's Avatar
i wouldnt think an adjustment will fix it, and the shift fork is inside the trans bellhousing. sounds like shes going to need a little work to fix it. shouldnt have to worry about driving on it if it still clutches and shifts ok in the other gears...good luck man...
Old April 16th, 2008, 02:45 PM   #8
VOLIPINO's Avatar
Yeah, the clutch is good, and shifting is fine, we'll see, i just bought the damn thing and replaced the fuel pump in it this past weekend, oh well.
Old April 16th, 2008, 03:20 PM   #9
jrh_1980's Avatar
89 Mustang LX
7.90@90mph 8th
jrh_1980 is on a distinguished road
do you have an oil leak. when 5th gear starts popping out it could be that it starved for oil. 5th sets highest in the case so if the fluid level is low it could be that. I had the problem in a VW i was working on and all it was, was the fluid. at least worth a check>
Old April 16th, 2008, 05:57 PM   #10
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
the gears could be chipped..if it shifts fine than its not synchros..i know i broke off a couple teeth on my reverse gear and it pops out every time the gear makes a full rotation..
Cohagan Engineering, Inc.
Old April 16th, 2008, 06:04 PM   #11
e3sean's Avatar
1988 lx
9.68@142
if u have an aftermarket stop screw shifter not adjusted properly it will deffinatle do that..
as far as the fork goes.. fifth gear has its own fork so that is why i tought it could be that but 5th gear is not a common fork to bend. i would check the adjustment on the shifter first and get back to us
Old April 16th, 2008, 06:06 PM   #12
e3sean's Avatar
1988 lx
9.68@142
fifth gear sits lower than any gears in the transmission...the actual syncroed gear is anyway the drive part attached to the chaft doesnt matter the oil will follwo the gear up to that.
try everything though it is only gonna get worse so fix it while u can..
Old April 17th, 2008, 10:55 AM   #13
VOLIPINO's Avatar
yeah, I was going to check the stops this weekend anyways. thanks for the help, i'll let you know
Threads Similar to: Trans question.
Trans question. VOLIPINO Modular Mustangs 0 April 16th, 2008 08:59 AM
trans question 5mustang0 5.0 Mustangs 18 March 4th, 2008 10:07 AM
Trans Question sundro2000 5.0 Mustangs 2 February 26th, 2008 05:27 PM
86 5.0 trans Question? 86foxgt 5.0 Mustangs 1 April 11th, 2007 11:07 PM
Trans question need help 00stang V6 Mustangs 14 February 10th, 2007 09:10 PM
