kinked fuel line?
Old April 17th, 2008, 02:05 PM   #1
stangomikes's Avatar
1986 5.0 GT vert
stangomikes is on a distinguished road
kinked fuel line?
my friend was replacing his fuel filter on his 82 5.0 and in the process he twisted the fuel line a little. Can this cause the car to run rough (i.e. backfire) if so what should he do? replace the only option? Thanks!!!!
Old April 17th, 2008, 02:23 PM   #2
ryans88gt's Avatar
Cut out the twisted part and replace it with some braided 5/16" hose and hose ends.
Old April 17th, 2008, 02:31 PM   #3
1986 5.0 GT vert
Should he cut or saw it? Also, should it be disconnected when he does it so their is no fuel or will it be safe either way? Thanks for the help!
Old April 17th, 2008, 02:33 PM   #4
alabamastanger's Avatar
1983 Mustang GT
N/A
alabamastanger is on a distinguished road
Thanks for the help Stango
Old April 17th, 2008, 02:44 PM   #5
ryans88gt's Avatar
release the fuel pressure at the schrader valve on the fuel rail. then disconnect the fuel line at the filter and drain whatever fuel comes out. Don't use a cut off wheel or you could start a fire. Use a small pipe cutter. If you can't get a pipe cutter around the line where it is kinked use a very fine hand saw made for cutting pipe. Depending on what type of fittings you can find, you could just use a flare tool and replace the kinked part with a union fitting. Personally, while you are messing with it, I would just replace the whole line with -6 AN braided line. You can get 15 feet from summit for $50 and it will push right over the stock fittings if you cut the nylon tube.
Old April 17th, 2008, 02:51 PM   #6
1983 Mustang GT
N/A
Where's the schrader valve? This is a carbed model by the way.
Old April 17th, 2008, 02:57 PM   #7
fastford3388's Avatar
1991 Mustang GT
fastford3388 is on a distinguished road
Send a message via AIM to fastford3388
just use a small pipe cutter and splice in some new steel line. you can get steel line from advance and 2 compression fittings. it should work just fine...
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
Old April 17th, 2008, 03:57 PM   #8
1983 Mustang GT
N/A
I have braided line, so will that work if I just cut the steel pipe, and put the braided line in?
Threads Similar to: kinked fuel line?
fuel line problem.. Speedstang302 5.0 Mustangs 5 February 25th, 2008 06:40 PM
Fuel line object zerofx150 99-04 3 January 28th, 2008 11:47 AM
fuel line 06WHTGT 2005 - 2010 5 December 22nd, 2007 10:22 PM
Fuel Line Sizes... sneezingfox 5.0 Mustangs 5 December 13th, 2007 02:21 PM
Fuel line jbm5781 96-98 18 August 15th, 2007 12:02 AM
