Flat-tappet 302 Cyl head swap
Old April 17th, 2008, 06:44 PM   #1
Mustangfan99's Avatar
Mustangfan99 is on a distinguished road
I have an 84 f150 with a flat tappet 302 in it that I am looking to put a set of Gt40 cyl heads in from an explorer, since the block i have is not a roller block, and the heads I will be putting in it are from a roller block am I going to have any problems? Or am I in the clear? any help is greatly appriciated, thanks!
V6 power!
Old April 17th, 2008, 09:59 PM   #2
1993 mustang lx convertib
saldoggs is on a distinguished road
you can put the heads on you will have to make sure the headers will clear the spark plugs the explorer heads have a different angle on the plugs then the regular gt 40 heads and make sure your push rods are the correct length and you should be fine
Old April 17th, 2008, 10:23 PM   #3
woody1 is on a distinguished road
the explorer came with 40's and 40p's if there 40's hes fine any header works, no difference just cause they were on an explorer
Old April 17th, 2008, 10:31 PM   #4
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
yeah just make sure you get the right length push rods
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old April 18th, 2008, 04:42 AM   #5
PJC Racing is on a distinguished road
The springs will have more spring rate but not so much that it should cause a problem.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Threads Similar to: Flat-tappet 302 Cyl head swap
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
Flat tappet vs. Roller? 95wip 5.0 Mustangs 7 May 3rd, 2007 11:21 PM
head swap Mustang RacR94 99-04 9 April 25th, 2007 05:27 PM
PI Head Swap therooster 96-98 6 October 19th, 2006 11:13 AM
Head Swap wikdsvt 5.0 Mustangs 5 October 10th, 2006 06:19 PM
