i wana pull off the upper intake manifold......
Old April 17th, 2008, 11:41 PM   #1
91cobra5.0's Avatar
98 Cobra
is it hard to take off? and do i have to replace the gasket if i do?
Old April 17th, 2008, 11:49 PM   #2
fogged306's Avatar
89 GT
Not really hard to do at all, just mark the hoses and wires you pull off with masking tape and a marker, usually works nice for me. Also get ziplock baggies for the bolts and label the bags too. and yes you will need to get a new gasket. Make sure you scrape the surface down if theres any gasket material left on there after you split the manifold, and stuff paper towels into the holes of the lower while you scrape so you don't get big chunks into your cc's.
Old April 18th, 2008, 06:07 PM   #3
humbleLX's Avatar
1989 LX hatch
humbleLX is on a distinguished road
also taking a few pictures of misc. vacuum lines, etc.
will make it a little easier the first time.... good luck.
GT40 crate Ecam 1.7RR GT40X alum head GT40 P1SC 12rib IC 12 psi 42inj AFM PMS IV PMAS 3" Flotube BBK 70mm TB 255 Walbro short hdr BBK o/r X, 2ch Flows, way too much to list... if it ain't blown, it sucks...
Black & Tan
Old April 18th, 2008, 08:35 PM   #4
ujslost's Avatar
no ya dont need a new upper gasket, unless some toolbag has glued it on for some dumb reason.
He asked about the upper intake. If he takes the lower off then yes you will need new gaskets for the lower.
To remove the upper there are 6 13mm bolts that hold that on. Then remove the 2 10 mm bolts that hold the throttle linkage on the EGR spacer. leave the throttle body and egr spacer bolted on, unless you have a reason for taking those off.
Old April 18th, 2008, 09:31 PM   #5
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
Why you wanting to pull the upper intake manifold??
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Threads Similar to: i wana pull off the upper intake manifold......
can i paint the 5.0 HO badge plate on the upper manifold? 91cobra5.0 5.0 Mustangs 4 February 24th, 2008 01:25 PM
Removal/install of upper intake manifold Stang6899 V6 Mustangs 9 February 14th, 2008 12:54 PM
gt40 upper/lower intake manifold MustangSparks 94-95 1 July 17th, 2007 04:14 AM
Upper Manifold line hookup help please. YNOT 5.0 Mustangs 2 June 15th, 2007 05:29 PM
Upper Intake Manifold terribleonexx88 5.0 Mustangs 6 November 15th, 2006 09:36 AM
