New Guy Needs Help (5.0 Runs Rough)
Old October 19th, 2006, 11:07 PM   #1
88MustangMarine11 is on a distinguished road
hey im new here i just bought an 88 fox body lx 5.0 its an auto and the idle is rough when put into gear and sometimes dies on me. any suggestion? ive been a mech for about 5 years now and i cant figure it out.
Old October 19th, 2006, 11:15 PM   #2
smbikes's Avatar
smbikes is on a distinguished road
sounds like the tps , cleand the top end yet , or check for air leaks
302 ci bored 40 over converted to carb, comp cams XE274HR cam .555/.565 lift, much more , dyno'd at 471.8 HP @ 5700 RPM!!
Old October 19th, 2006, 11:18 PM   #3
TENGRAM is on a distinguished road
Check for Codes. it probably is something simple like gear switch, speed sensor, or IAC...the codes will tell us for sure. let us know
89 GT t5 3.73
www.my5oh.com/
Old October 19th, 2006, 11:20 PM   #4
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
take off the idle air control unit spray it with carb cleaner thro it back on,check the spark plugs gaps or just put new ones on and check your wires,check for vacuum leaks, and turn up the idle a tad and see what happens
85 svo. work in progress
Old October 19th, 2006, 11:22 PM   #5
i wouldn't adjust the idle until you know whats wrong with it...that usually leads to a surging idle. my2cents
89 GT t5 3.73
www.my5oh.com/
Threads Similar to: New Guy Needs Help (5.0 Runs Rough)
First runs at the strip HessiaN257 99-04 11 October 13th, 2007 12:30 PM
Runs rough below 3k or so.. alabamastanger 5.0 Mustangs 3 July 9th, 2007 02:01 AM
Runs jonnotch 5.0 Mustangs 1 June 9th, 2007 07:52 PM
dyno runs ozan169 2005 - 2010 1 February 4th, 2007 11:37 AM
Car runs rough chase 5.0 Mustangs 8 December 24th, 2006 07:44 PM
