Crankcase Evacuation Systems
Old October 20th, 2006, 12:32 AM   #1
smbikes's Avatar
smbikes is on a distinguished road
what do u guys think about it , thinking of putting one on my car to fix my pvc problem http://store.summitracing.com/partdetail.asp?autofilter=1&part=MRG%2D6002&N=700+ %2D115780+115&autoview=sku[/url]
302 ci bored 40 over converted to carb, comp cams XE274HR cam .555/.565 lift, much more , dyno'd at 471.8 HP @ 5700 RPM!!
Old October 20th, 2006, 12:34 AM   #2
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
whats your pcv problem
85 svo. work in progress
Old October 20th, 2006, 12:36 AM   #3
smbikes's Avatar
no were to get vac from and blows my rear oil seal , a problem i know well, lol
Old October 20th, 2006, 12:41 AM   #4
isnt there knock outs on the bottom of the edlebrock air cleaner to hook up lines
Old October 20th, 2006, 12:48 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Vacuum pump would be my first choice. The next choice woud be a car spacer with a vacuum port like http://store.summitracing.com/partde...0&autoview=sku
Those crank case evac kits that tap into the headers don't work well on the street because they are designed to be used with open headers. An exhaust system creates too much back pressure for the evac system to function properly.
Old October 20th, 2006, 01:14 AM   #6
smbikes's Avatar
but i have the nitrous plate
Old October 20th, 2006, 02:35 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can still run that TransDapt spacer. I did for along time for my power brakes (when I had them) with my plate system.
Threads Similar to: Crankcase Evacuation Systems
Exhaust Systems Snipe061 V6 Mustangs 3 March 6th, 2007 11:08 AM
Exhaust Systems! FastBack71 Modular Mustangs 5 February 26th, 2007 04:42 AM
exhaust systems villatic V6 Mustangs 20 January 29th, 2007 10:38 PM
Intake systems shurb125 5.0 Mustangs 5 December 30th, 2006 10:14 AM
Exhaust Systems... bcp5008 V6 Mustangs 15 September 5th, 2006 12:16 AM
