331 started missing today
Old November 4th, 2005, 01:02 AM   #1
groundpounder is on a distinguished road
All of a sudden, my 331 started missing today. I got home and noticed that the boot was torn off the #4 plug, but the lead was still attached. It just didn't have insulation. I'm thinking that's my smoking gun along with the fact that #1 was loose enough on the plug that I was pretty sure it wasn't make a connection. (Grandaddy always said check the small stuff first). I am definitely going to replace the wires, and also the cap, rotor, and plugs while I'm at it here. have a concern and some questions. First, the questions:
I have Victor, Jr. heads. Any suggestions on "hotter" plugs, or do you guys feel I could make more power by putting more timing in it and dropping down a notch?
Any suggestions for wires? Some will say they're all the same. I'm thinking that I will order a set of 9MM racing wires off eBay. Or just get in the Zone if they have something that looks decent.
Why the hell would someone pay over $250 for wires? Are these really that good? Anybody used them??
http://cgi.ebay.com/ebaymotors/Nolog...QQcmdZViewItem
I mean, C'MON!!
Here is the concern:
Car's been running a little rough, especially when it's cold. But now it's doing it a little more, like when it's under a load at 1,500 rpms in 3rd or 1,000 in 2nd - you know, not quite lugging but not on the cam yet, either. Seems like it's firing down in the header, not backfiring or booming out the tailpipe, but spitting down into the header.
Best case scenario, it's just the cam making the car fussy.
Worst case, I have a exhaust valve that is allowing some blow-by.
Any thoughts?? THX, ladies!
cheap
fast
reliable
Pick two - Juggy
Old November 4th, 2005, 02:03 PM   #2
sAJ1420's Avatar
2000 Audi S4
sAJ1420 is on a distinguished road
Send a message via AIM to sAJ1420
ladies
A U D I //S4 2000 6MT/TT/AWD
Stage 3 in the works.. 460+ awhp 455 lb/ft torque, 500+ awhp on race gas
Old November 8th, 2005, 09:29 PM   #3
The miss is gone! I did the "top end tune up" with new cap, rotor, wires and plugs, and man did it make a difference (no sh!t, sherlock!)
But seriously, it had to add like 450 rwhp or something. schwing!
The dead miss is gone, and my little firing down in the header problem has been lessened, but is still there. I'm worried about a burnt valve.
Any thoughts, gurus? Share the nollij!
cheap
fast
reliable
Pick two - Juggy
Old November 9th, 2005, 10:57 AM   #4
Only if they came with stickers... j/k
seriously though, if it has a burnt valve it would still run rough. Have you done a compression test? That would be what I would try next. Also, make sure it isn't an exhaust leak somewhere or a thermactor problem, if it's still hooked up.
88 Mustang Coupe
www.rickscarcare.net
Old November 9th, 2005, 09:25 PM   #5
compression test this weekend. Only does this intermittently, and the car is consistently strong so a burnt valve hopefully is not going to be my problem. If I let out of the throttle and ease it for a few seconds or if I go into it harder, it goes away and doesn't come back.
The thermactor appears to be loose and it won't stay in place. I didn't think that could cause some of the problems I am having. Hmmmmmmm
cheap
fast
reliable
Pick two - Juggy
Old November 9th, 2005, 10:25 PM   #6
the thermactor could be the cause of the sputtering inthe exhaust. disconnect it and see if it still does it.
88 Mustang Coupe
Old November 11th, 2005, 01:18 PM   #7
How do those things work and what is their purpose?
cheap
fast
reliable
Pick two - Juggy
Threads Similar to: 331 started missing today
How my day started WAR-PARTY The Clubhouse 5 September 28th, 2007 02:25 AM
project has been started guys!!! droppedbass87 96-98 19 August 12th, 2007 12:18 AM
My whole car started shaking... Really bad vibrations ??? 1911A1 5.0 Mustangs 8 February 28th, 2007 09:13 AM
Help in getting Engine Started jei3270 Classic Mustangs 6 January 12th, 2007 07:51 PM
forum started beheivjer The Clubhouse 8 February 28th, 2006 08:20 PM
