3rd gear clattering
Hey how are you guys doing. Alright here is the problem. I just intalled a tremec transmission into my car this morning and it works great except 3rd gear it clanks, clatters whatever u want to call it. But its only in 3rd gear. all of the other gears work perfect. I am really stumped. I don't know if the clutch is clattering with the pressure plate or the clutch isn't adjusted enough for 3rd gear to catch all the way, or if the syncros are shot on the gear. It only happens when I step on the gas, any rpm, any throttle. It goes into gear perfect, no grinding, nothing but if i do not touch the gas it goes fine no noise. Only when I step on the gas.
Thanks in advanced. Looking to work this problem out tomorrow. Any help would be great. Bobby
'89 LX 5.0- bored .30 over, Edelbrock Performer Heads, GT40 lower and upper, 70 mm BBK TB, custom grind cam, BBK U/D pullies, UPR A/C eliminator, BBK LT headers, BBK O/R X Pipe, 40 series flows, MMC LCA, Eibach lowering springs. |
I was gonna make a post but i'll just bump this one up cuz i am have thee exact same problem just that it is 5th gear.
1991 mustang 5.0
My car does this in 5th, or whenever i should downshift and i press the gas instead. My problem has to do with the driveshaft though.. don't kow if yours could be related
1991 mustang 5.0
Not sure it's exactly my driveshaft. I know it's either the u-joints, yolk, or the driveshaft is out of balance.
98 Cobra
id think ur gear is going out
Threads Similar to: 3rd gear clattering
| Cam gear and camshaft position sensor gear... | 99v6stang | V6 Mustangs | 17 | January 17th, 2008 02:00 PM |
| Does anyone use gear to gear timing? | e3sean | 5.0 Mustangs | 24 | December 27th, 2007 02:37 PM |
| Clattering 93 fixed! | BigBlockFairlane | 2.3 Mustangs | 2 | November 25th, 2007 02:58 PM |
| My 2.3 Is Clattering-Question | BigBlockFairlane | 2.3 Mustangs | 5 | November 23rd, 2007 01:47 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 05:22 PM |
