Fuel problems....Any help?
Old April 20th, 2008, 10:59 AM   #1
Casper98GT's Avatar
Have a 1993 Mustang LX 5.0 hatch, manual. Ok....
Stock as can be, with the exception of 3.55 gears, flows catback, sn95 fuel rails, BBK adj. fuel regulator, Trickflow upper and lower w/ 1 inch spacer and JLT CAI.
Problems before, hard starts. terrible gas milage ( 121 per tank not beating on it ) when running with 13* of timing and set at 38psi of fuel pressure when keying it off i would have no fuel pressure. Doesnt hold.
First thoughts were bad adj. fuel regulator, removed vaccum line...no fuel. So thought it was good visually. Didnt check fuel pump because its in my tank. But its stock to my knoldege. Also thought fuel injectors were leaking...nope. Keyed it up with them off and they all hold pressure.
I have my car now with no exhaust and down to a bare block.
Its a project and will post a Project thread to keep youre eyes open. Going H/C/I and vortech intercooled.
Anywhoo....took off the upper intake and found when looking at the first 4 holes on the gasket which would be ( 1, 5, 2, 6 ?? ) the last one was super wet. Both gaskets and spacer was. Then the last 4 holes were all wet. So after removing the upper portion i found the vaccum log hose to the intake was wet.
Checked out the vaccum line going from the adj. fuel regulator to the intake was rubbing in two places, one place very lightly. the second place looked like possibly kinked or a pin hole through it. But i thought if it had that it would stall. But doesnt runs pretty well and idles nice. Just terrible gas milage and hard starts.
Im confused....need help.....
Maybe it will magically be fixed. Its down to bare block right now and getting Bassani equal lenghts, BBK catted pipe and catback. GT40X heads, 1.6 RR's, trickflow intake, f-cam, 24lb inj's and MAF. Maybe it will fix itself. haha. i doubt it.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old April 20th, 2008, 11:28 AM   #2
ujslost's Avatar
subscribing.
Talked to casper about this problem, and I cant make heads or tails of the gasmilage or the long starts.
Old April 20th, 2008, 01:45 PM   #3
vfast will become famous soon enough
it could be an injector problem, your f/p will bleed off over a small amt of time....Iwonder if you floored it,it would start right up..was tps good? egr unclogged? was maf calibrated?
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old April 20th, 2008, 04:08 PM   #4
Casper98GT's Avatar
i keyed it up with all injectors in the rails and none of them leaked. thats my first thoughts. fuel pressure bled off immediatly. i know what you mean by flooring it when starting by killing injector pulse. but i never tried it. it ran very nice and the egr was not clogged. the maf is stock and also the 19lb'ers were stock.
unfortunatly i cant try any tests right now because the car is down to bareblock. i alsoscanned it with an NGS and came up empty handed as far as codes go.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old April 20th, 2008, 08:59 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sounds like a bad injector(s) or possibly a fuel leak. Pulling spark plugs right after you shut the car down should tell you if you have a leaking injector.
Old April 21st, 2008, 12:23 AM   #6
Casper98GT's Avatar
Well i pulled them shorty after i started it and pulled into the garage. And no signs of problems on the plugs. Which is mind boggling in itself. I am including some pics of the teardown and problem areas. Hope it helps.
91 LX, 5spd.
Ex:Toyota/Ford tech
Threads Similar to: Fuel problems....Any help?
1997cobra fuel problems roushling 96-98 7 April 7th, 2008 02:48 PM
fuel pump problems roush 2001 5.0 Mustangs 4 March 16th, 2008 11:42 PM
Fuel Problems 1fstcobra 99-04 14 December 10th, 2007 10:43 PM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 06:48 PM
Fuel Pump Problems bigbadtalontsi 5.0 Mustangs 5 March 30th, 2007 04:50 PM
