Adjustment??
Old April 20th, 2008, 09:52 PM   #1
jonnotch is on a distinguished road
Adjustment??
I bought a upr firewall adjuster and I have maximum motorsports clutch quadrant. So I need to buy a stock OEM cable. I looked at them and there is an adjuster on teh end how does that work with a fire wall adjuster? Is there just two points of adjustment?
Thanks
Jon
1992 Mustang Notchback-306, road race project.
Old April 20th, 2008, 10:14 PM   #2
acg
acg's Avatar
1996 Mustang GT Conv.
1985 Mustang GT Conv.
acg is on a distinguished road
Yes with that one you would have two points of adjustment, but there is another cable that is non adjustable(it looks like a metal mushroom at the end) so you could get that one so you won't have to mess around under the car.
Old April 20th, 2008, 11:57 PM   #3
Does ford sell this cable or do I have to call around?
Old April 24th, 2008, 01:00 AM   #4
acg
acg's Avatar
They might but I got mine from 50resto but it also came with a clutch fork.
Old April 24th, 2008, 01:32 AM   #5
neverfastenough1's Avatar
I set my firewall adjuster to mid way. Then I adjusted my cable to take the slack out. Setting my firewall adjuster to center gave me room to adjust the pedal up or down to get the right height without having to crawl under the car again. I just adjusted it with the firewall adjuster to where it started grabbing a little less than half way to the top. Any closer to the top and you take a chance on the clutch not engaging all the way. Supposedly the stock cable is stronger than the adjustable one, or at least it doesn't stretch like the adjustable has been said to do. I have the adjustable one with no problems yet.
Old April 26th, 2008, 10:11 PM   #6
Thanks for the info.
Threads Similar to: Adjustment??
tps adjustment SHAKEY8 5.0 Mustangs 5 October 20th, 2007 10:41 PM
Valve adjustment 91 5.0 lx hatch 5.0 Mustangs 7 September 26th, 2007 03:00 PM
Speedo adjustment?? :S 1988 convertible 5.0 Mustangs 2 June 4th, 2007 11:33 AM
E- Brake Adjustment? chris1 Modular Mustangs 1 May 28th, 2007 06:37 PM
valve adjustment 86_Notch 5.0 Mustangs 0 March 28th, 2007 09:48 PM
