this is a t-5 question for e3sean and anyone else who might know!
Old April 21st, 2008, 01:21 AM   #1
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
ok so as most of you know (and if you didnt know shut up) that i have a mustang II, my build that im doing is going to involve a t-5. because a mustang II has some clearence issues in the transmission tunnel, i need to use the bell housing from my origanal 4 speed (the bell housing is thinner but longer) so that i can use the headers i have, and because of that reason, i need to use a t-5 out of a 94-95 because they have the slightly longer outputshaft. then have a custom pilot bushing made, and also have the thrush bearing sleeve plate milled .010 to fit snug in the II bell housing.
and i was wondering if only the output shaft was longer? is the rest of the t-5 normal? i have found a t-5 that is no good, but its out of a 91.
so basically my question is could i use that trans, and then get a kit (tremec or another good after market kit) that is made for a 94-95? (this assuming it comes with a output shaft from a 94-95, and if the kit doesnt have a output shaft, could i get the shaft from one of those years?
Old April 21st, 2008, 02:24 AM   #2
e3sean's Avatar
1988 lx
9.68@142
if u know that u can bolt a t-5 up to that bell housing all u will need is the input shaft for a 94/95 but u have to make sure its the same tooth count on the shaft which is 4th gear so yes u can get the transmission and i might have an input shaft for you if it is the same tooth count but even if its not i know where u can get a new one for around 70
<font size=4><b>MILITARY CREW
Old April 21st, 2008, 02:47 AM   #3
e3sean's Avatar
1988 lx
9.68@142
I forgot to tell u that it was the input shaft is what u were thinking of the input shaft is what rides in the pilot bearing and what the clutch disk sits on behind that is the main shaft sometimes called the tail shaft then under that the counter shaft also known as the cluster gear.
Old April 21st, 2008, 11:37 PM   #4
78mach1's Avatar
haha i knew i would get input from you!
well bolting the t-5 up to my bell housing is the popular thing to do, i know that when using that input shaft from a 94-95 the input shaft is only riding about 3/16th`s of an inch inside the pilot bushing, so i will have to have one made that is a tiny bit longer.
so i need to find a trans, then get the tooth count?......and go from there (looking for a 94-95 input shaft with the same count?)
ok and as far as kits, what would you recommend?
ohh ya sorry i was a little tired last night. input-output, whats the difference lol
Old April 26th, 2008, 04:42 PM   #5
78mach1's Avatar
ok so im trying to do this as low dollar as possible but not have a peice of junk when im done
so my buddy has a blown t-5 out of a 305 camaro, i was wondering if i could use this this case, and get a 94-95 input shaft, and then build the internals cause i know that they werent world class ones, so basically could i use this transmission
Old April 26th, 2008, 08:39 PM   #6
e3sean's Avatar
1988 lx
9.68@142
no you cant use a comaro t-5 it is proly a non world class t-5 and will do u no good.
just get a mustang t-5 and put a 95-95 input shaft on it.
is there any way u can use the other bell housing? is it a matter of differnt headers?
Old April 28th, 2008, 12:09 AM   #7
78mach1's Avatar
well the tunnel on my car (mustang II) is narrow so with a t-5 bell in it, i have absolutley no room for my headers, but by using the RAD 4 bell housing, and just milling the thrush bearing sleeve flang. i can easilly clear my headers and any other header i plan on using in the future (thats a popular thing to do with my car)
i havent been able to find a t-5 that is reasonably priced, and not a total peice.
Old April 28th, 2008, 02:49 AM   #8
e3sean's Avatar
1988 lx
9.68@142
well any rebuilt t5 is gonna cost anywhere from $550 (which is what i sell them for) up to 900 and some people want a core too... if you want one from me it will be around 700 after packing and shipping unless u wanna take a trip down to az but it will cost u more in gas then anything else.
Old April 28th, 2008, 11:40 AM   #9
78mach1's Avatar
you could build one with a 94-95 input shaft for 700?....is that with or without the bell housing?
do you just use oem kits?
Old April 28th, 2008, 12:32 PM   #10
Hunt_chevs's Avatar
2002 Gt
Not Slow
hahahaha, i love this forum... I wonder if any chevy forums are this wholesome..
ps... im not knocking your whip...as long as it squats and digs. and mashes cheby's of course..than its otay by me
Old April 28th, 2008, 12:38 PM   #11
78mach1's Avatar
haha why thank you, im currently waiting to race my friends 68 camaro (daddys car) this kid doesnt know anything but what year his car is, and that its got alot of chrome!
im just trying to get a t-5 in it so i can make a run with this dummby
Old April 28th, 2008, 01:02 PM   #12
e3sean's Avatar
1988 lx
9.68@142
yes i can put the 94/95 inputshaft on it. no bell housing though sorry.
it would be a rebuilt t-5 yes all the parts are oem.
i can put a steel bearing retainer and a billit steel thrust plate on it for you for $100 then it will hold a good amount of power over stock the 100 just covers parts i dont charge to put it on cause i dont have to do anything special when i put it on.
Old April 28th, 2008, 01:24 PM   #13
78mach1's Avatar
ya its cool, i dont need the bell housing anyway
ok so you would build a world class t-5 with a 94-95 input shaft, and a steel bearing retainer, along with a stell thrust plate for $800 after shipping?
Old April 28th, 2008, 02:36 PM   #14
e3sean's Avatar
1988 lx
9.68@142
yep... i actually have one here thats already built i would just have to take the tail housing off and put a thrust plate on.. when are you looking to have this done?
Old April 28th, 2008, 09:56 PM   #15
78mach1's Avatar
well the car its going in curently is sitting on jack stands with the driveline out, im planning rear disc conversion as well as a better set of gears, freshin up some bushings and a few other things. and most of the interior is out, its getting ready to be painted soon
i will just need to see how soon i could pay you if i decided to go that route
Old April 29th, 2008, 02:36 AM   #16
e3sean's Avatar
1988 lx
9.68@142
sounds good just give me a few weeks advance and like 200 down so i can get ont together....
Threads Similar to: this is a t-5 question for e3sean and anyone else who might know!
E3sean Needs To Get His Car To The Track Fund. e3sean The Clubhouse 12 April 28th, 2008 12:36 PM
88' GT Speedo' Question. Plus Another Gauge Question. Mr_Evil 5.0 Mustangs 8 March 16th, 2008 01:31 PM
hey e3sean u might like these 91cobra5.0 5.0 Mustangs 1 March 2nd, 2008 11:53 AM
Exhaust question + supercharger (warranty) question r00st 2005 - 2010 2 January 31st, 2008 11:07 AM
Muffler question (visual aspect) + Emblem question warrior86 Visual 5 November 20th, 2007 09:55 PM
