#1 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Smog delete
Well i did the delete a long time ago but i never got around to taking the tube off from the back of the heads. I started it last night and my friend sent me a write up from here. the bolt used in the write up was a 9/16-12 well i got all the part needed and when it came time to plug the holes i got the 9/16 bolt and the damm thing would not fit in!
So with out thinkin i went back to the store to pick up a 1/2 bolt.... Now back home i tried to put it through. ahh hah it worked, until i went to torque it down then it back out. So you ask what happened, CARBON build up. So i cleaned the holes out with the 1/2 inch bolt and then tried the 9/16-12 again and what do you know it worked! So for anyone who is doing this, make sure you clean you holes out cause they may be gunked up![]() Tim PS it cleaned up the engine bay nicely
Military Crew USMC
Threads Similar to: Smog delete
| Smog & A/C Delete | whitefox89 | 5.0 Mustangs | 42 | December 31st, 2011 01:14 AM |
| smog and ac delete... | e3sean | 5.0 Mustangs | 7 | March 1st, 2008 01:31 PM |
| AC Delete and Smog Pump Delete | triplethreatt77 | 5.0 Mustangs | 14 | December 24th, 2007 06:09 AM |
| Smog Delete? | 95blackbeauty | 94-95 | 8 | December 20th, 2007 02:44 AM |
| Smog Pump Delete | mdvaldosta | 5.0 Mustangs | 2 | September 11th, 2006 11:13 AM |
