LinkBack (1) | Thread Tools |
#1
88' Coupe & 92' HB
SCAT Rod issue
I bought a NEW SCAT balanced rotating assembly (331- I got a good deal on it). I go to remove the caps from the rods and find that one of the rods has a crossthreaded cap screw. I call SCAT and they are out of stock on 5.4 rods until the middle of May. I asked if this was a fluke or if he had ever heard of something like this. He told me it could be any # of things.
So now I have to wait until I can get a rod from them with the correct weight to finish my build.
88' Coupe & 92' HB
WTF!!! I am never buying anything from SCAT again. I still do not have a rod and they are telling me the end of June now. I was watching Speed channel's Chop, Cut, Rebuild show and they had a chevy rod that came from SCAT the same way. SCAT told me they could upgrade me to H beam rods for a small fee, but I would have to get everything rebalanced. I am suppose to hear from them on Monday what they can do, I told them I should not have to pay anything for their screw up.
On the brighter side, I have had more than enough time to get the K member installed, the fuel system (1/2" line, Holley blue pump, regulator, etc,) installed, shifter, exhaust system fitment and a ton of other things done. I have an extra 302 block and an empty C4 case that I used to mock everything up with. The BBK long tube headers and o/r h-pipe fit with a little adjusting with a BFH on the tube closest to the starter (needs 1/4" more space with the small bellhousing). Transmission (C4) has gotten the six pinion planetary with a low drag set installed. I will be running a 3000+ stall converter (custom from Camrod convertors out of Columbia, SC). |
88' Coupe & 92' HB
SCAT sent the H-beam rods out Friday and I should have them this week. I have to take everything to a local shop and have it rebalanced. Summit is going to credit me the cost of the balance towards a future purchase (aluminum driveshaft
). So I hope to have everything in and running by July so I can make it to Mustang Week in Myrtle Beach, SC).
I have heard of the rod bolt issue before. It is a galling issue. Seems like about 1 in 16 rods have a f'ed bolt.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Isn't there some type of specialized substrate or dry coating that could be put on the bolts to reduce the chance of galling? I know there are many chemicals used for similar industrial purposes. Just asking. I've never built an engine.
well I guess you wouldn't want the bolts to come free very easily, I don't know, but I'm thinking they just have a QC issue that needs to be addressed. I think scat's rods come from China.
88' Coupe & 92' HB
SCAT rods do come from china, I found out after I ordered and had the issue. The guy at SCAT said all aftermarket rods are forged in China and shipped to US for machining. I told him I know that there are rods made in the US and his response was "Yeah and those rods cost $1500 a set." I told him that was BS and he said that yeah some rod makers say that they are US, but they are only machined in the US. I originally thought I got the 1 rod out of a million (figure of speech) that this F'd, after a little more research it seems this is not so uncommon.
#8 | |
#9 | |
88' Coupe & 92' HB
I say I will never buy from SCAT again because of the way the handled the issue. Noone is perfect and I understand that, but when I get told that they will do something to remedy the issue and after 2-1/2 months nothing has been done. That is poor customer service in my book and that is what separates a good company from the rest. SCAT kept telling me there was nothing they could do until they got more rods in from China in the middle of May. OK. Well, May came and went and no rods. I call and they say end of June they hope. I tell them it is not acceptable and they say for a small cost to me they will upgrade me to H beam rods. What? Small cost? I call Summit, they call SCAT and I get them at no charge. Summit tells me that I should have went with an Eagle setup from the start. I almost went that route to begin with, but was offered $$$ off of a SCAT assembly. That is my fault for trying to save a little $$$.... Live and learn...
#11 | |
88' Coupe & 92' HB
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/67508-scat-rod-issue.html
| SCAT Rod issue | This thread | Refback | May 20th, 2008 12:36 AM | |
Threads Similar to: SCAT Rod issue
| Cat issue | FireryDriver | 2005 - 2010 | 19 | February 27th, 2008 07:37 PM |
| Febuary MM&FF Issue! | MustangMatt96GT | The Clubhouse | 99 | January 12th, 2008 03:28 PM |
| weird issue | Newtgadget | 5.0 Mustangs | 3 | October 27th, 2007 01:16 PM |
| here is my issue | bigbadwollfff04 | Drag | 35 | July 5th, 2007 10:34 PM |
| t5 issue | 342stroker | 5.0 Mustangs | 3 | June 4th, 2007 10:41 PM |
