Discussing Correct way to adjust fuel pressure? in the 5.0 Mustangs Forum. I have an under hood gage and I was wondering the correct procedure to adjust ...
Old April 23rd, 2008, 05:48 PM   #1
1993 GT
13.2@105
I have an under hood gage and I was wondering the correct procedure to adjust fuel pressure because when I do it the car starts surging and shuts down.
Old April 23rd, 2008, 07:32 PM   #2
nolife's Avatar
You do have an adjustable FPR right? The stock one is not adjustable
Remove the vacuum line and temporarily plug or crimp it and adjust the FPR for 39#.
Surging related to fuel pressure can be caused by too much fuel pressure or in some cases, larger then stock injectors can surge at the stock setting at 39#, if that is the case, try something a few pounds lower and see if that helps. You may also have other surge related problems and the fuel pressure is making it worse.
1991 GT - Original owner, all stock
1988 GT - The project car
Old April 23rd, 2008, 11:14 PM   #3
ryans88gt's Avatar
^+1 solid info.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old April 24th, 2008, 04:36 PM   #4
1993 GT
13.2@105
I have a 306 with trickflow heads, cam,intakes,full exhaust etc...and I have it set at like 25 to 30ish and I thought that seemed alittle low but it surges when I raise it.
Old April 24th, 2008, 04:47 PM   #5
nolife's Avatar
That seems to low. Assuming your gauge is right, I'd take your pressure back up and start the process to eliminate why its surging. There are plenty of old threads on MM and many other places online that go into extreme detail on tracking down fox body idle surging.
Old April 24th, 2008, 04:54 PM   #6
1993 GT
13.2@105
yeah I was looking at some yesterday,it just seems weird to me that it gets that much worse with just a little pressure increase.
Old April 24th, 2008, 08:24 PM   #7
ryans88gt's Avatar
It can happen. My 89 runs like crap with more than 35 PSI and 30 lb injectors.
88 GT 11.4 @ 118
Old April 24th, 2008, 08:36 PM   #8
1993 GT
13.2@105
thats about the pressure mine gets to before it gets pissed off at me.....
Old April 24th, 2008, 08:36 PM   #9
'93 Notchback 5.0
I thought 43 was more accurate with an adjustable, I think aeromotive even recommends an initial setting of 48. This is a mod I've been researching a little and those pressures just seemed a little low?
Old April 25th, 2008, 12:23 AM   #10
90 lx notch's Avatar
1990 mustang lx notch
no track time
stock is 39 mine is at 35 and the engine runs good
90 LX NOTCH
elec. fan, fenderwell intake, adjustable fuel reg w/ gauge, 75mm pro-m meter, 75mm ford racing tb and egr spacer, bbk pulleys & headers & offroad x-pipe, slp catback, 5 lug conversion, bullitt rims, 3.73 gears, battery relocation
Old April 25th, 2008, 12:43 AM   #11
ryans88gt's Avatar
I like to run mine at 30 PSI vacuum on since it hits about 100 PSI during boost.
88 GT 11.4 @ 118
Old April 25th, 2008, 10:15 AM   #12
nolife's Avatar
My base is at about 35 (80 with the FMU) and I get surging every once in a while. A 2 or 3 second rev above 2k usually makes it settle back down. I feel like an idiot sitting in traffic revving it though. Its like I'm calling out to everyone near by that I want to race or something. "No I'm not trying to be cool, I'm just trying to keep my car from stalling. Move along, nothing to see here" At least some other fox body owners will yell out, dude, idle surging?
I'm finally getting some dyno and A/F time on Saturday so I'll see if that is a good setting for me. I'm only pushing 10# boost and my 6k rev limiter pill in so hopefully I don't blow a head gasket
I have a feeling I'm not going to be satisfied with the results.
Old April 25th, 2008, 11:08 AM   #13
ryans88gt's Avatar
Take out the 6K pill and rely on the stock rev limiter. It is actually softer than the MSD.
I'll bet you are better than 400 at the wheels.
Try dropping your base fuel pressure, it really settled my car. Also, play around with different clocking rotations of the MAF.
88 GT 11.4 @ 118
Old April 25th, 2008, 02:35 PM   #14
1993 GT
13.2@105
Ryan, can you explain different clocking of the maf for me, thanks
Threads Similar to: Correct way to adjust fuel pressure?
How to adjust fuel pressure w/o an adjustable regulator Twist 2 Go 5.0 Mustangs 26 November 6th, 2007 10:46 AM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 12:41 PM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 07:58 PM
98 gt fuel pressure adjust beheivjer Modular Mustangs 2 June 4th, 2007 11:41 PM
what is the correct fuel pressure beheivjer Modular Mustangs 17 May 24th, 2007 09:12 AM
