major vibrateing comeing from rear of car
Old April 24th, 2008, 01:00 AM   #1
Look Ma! My First Post!
DBurner is on a distinguished road
Question
I was wondering if any body has any ideas on what would make my 93 5.0 vibrate a bit. And it dose not seem as responsive as before this started to happen? Anybodys help or sugestions are welcome!!!!
thanks
DB
Old May 5th, 2008, 05:03 PM   #2
Variety=Spice is on a distinguished road
any more details? related to acceleration? low speeds and high speeds? does it change when you're taking a sharp curve?
Old May 5th, 2008, 07:55 PM   #3
'02SilverBullet's Avatar
'02SilverBullet is an unknown quantity at this point
My bet is on drive shaft U joints!
If its an auto try holding the brake and shift into drive.... then to reverse... then back to drive.... just back and forth a few times to see if you can here a clanking noise comming from the drive shaft area when the car engages into gear. Ya know how a auto car will "lurch" forward and back while holding the brake? Well if you feel it lurch and here a noise with it then it is prolly a U joint.
Mods Include......
BBK CAI
MM Caster Camber Plates
Baer Decalla Drilled and Sloted Rotors
w/ painted callipers
Hypercoated 18x9 FR500 Rims
Eibach Pro Kit Lowering Springs
More to come.....!
Old May 14th, 2008, 12:26 PM   #4
1986 Mustang LX
N/A
Foxbred is on a distinguished road
I am having this same problem at 65 mph and above. I've been told that it could be my driveshaft, pinion angle, my tires my need to be rotated, my bearings, Im stuck myself. Im looking for advice, too.
Old May 14th, 2008, 01:43 PM   #5
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
harmonic balancer. look at the balancer with it running and see if it wobbles at all. also check it when its not running and see if it looks worn at all.
Old May 14th, 2008, 01:59 PM   #6
1996,mustang
around 5's 0-60
white_fang is infamous around these partswhite_fang is infamous around these partswhite_fang is infamous around these partswhite_fang is infamous around these partswhite_fang is infamous around these parts
it could be your rear axle mine did the same thing and it stop when i put a 8.8 in but it could be other stuff like your upper or lower control arms in back
Old May 15th, 2008, 12:34 AM   #7
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Id check your U joints on both ends. tranny end and pinion end.
also check your trans fluid level, and differential oil level
Mods in garage. Built suspension and gears since posted times.
Old May 15th, 2008, 09:09 AM   #8
1986 Mustang LX
N/A
Thanks for the info.
Threads Similar to: major vibrateing comeing from rear of car
Need Major Help Speedky Audio/Video 2 April 4th, 2008 11:03 PM
Need major help sundro2000 5.0 Mustangs 1 March 13th, 2008 06:33 PM
Need help with major problem drumvudu 2.3 Mustangs 3 March 13th, 2007 11:03 AM
Smell Of Rubber Comeing From My Engine white02GT 99-04 14 September 25th, 2006 12:47 AM
I need major help yellowgtstang18 99-04 3 June 22nd, 2006 01:04 AM
