Discussing GEAR questions? in the 5.0 Mustangs Forum. I currently have a 4.10 gear in the rear and i feel like im ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
89 Mustang LX
GEAR questions?
I currently have a 4.10 gear in the rear and i feel like im not utilizing the torque of the motor. I think that if i went to like a 3.73 i might notice an improvement. don't get me wrong it launches hard but i spend more time shifting than anything else. I had a thought, please chime in if i am way off course here. if i buy a 3.55 gear set and did some mis matching i could end up with 4 possible variations. 3.55, 3.73, 3.90, 4.10. does the tooth pitch change with the different ratios?
88 Gt
Not Slow
i can only agree more. i went with 3.73s
1988 lx 5.7
11.6@109
i would love to find a set of 3.90 for mine
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331 MILITARY CREW USAF LUKE AFB AZ, E-5 SELECT 7995 AMMO I.Y.A.A.Y.A.S |
1988 lx 5.7
11.6@109
have you ran the quarter mile where were you at the end of it? like the end of forth the beginning of fifth?
#5 | ||
Chicken Plucker
1986 Mustang GT
Location: Smothering v606er with a plastic walmart bag in the back woods of Michigan
I got 3.73's and I wouldnt go any lower
Like numericaly higher
![]() Members Against Mods Crew member #1
![]() 342 Stroker under construction |
89 Mustang LX
I haven't run the quarter yet. I am going to wait to do any gear changes til after I see how i do.
1986 lx notch
10.78 @ 124.96
run a taller tire an see if your car likes it better, if so then get the 373s , if not keep the 410
1990 mustang lx notch
no track time
+1 good idea
90 LX NOTCH elec. fan, fenderwell intake, adjustable fuel reg w/ gauge, 75mm pro-m meter, 75mm ford racing tb and egr spacer, bbk pulleys & headers & offroad x-pipe, slp catback, 5 lug conversion, bullitt rims, 3.73 gears, battery relocation |
you cannot mismatch gear parts. The ring gears and pinion heads are different thicknesses. I personally would want 4.10 gears unless I was running the 1/8th mile and then I would go for 4.56 or higher. You will not notice that much of a difference with 3.73s vs 4.10s. it is only like 100-200 rpm difference.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
89 Mustang LX
thanks ryans88. I was wondering if the pitch and stuff was the same or not. my current tires are 275/50/15 BFG drag radials. I was thinking about going with a 275/60/ 15 MT drag radial. it should be almost 2 inches taller will that make much difference.
1965 Mustang Fastback
then your gear ratio will be closer to 3.73 just do that
Threads Similar to: GEAR questions?
| gear questions... | zmaier | 96-98 | 4 | March 20th, 2008 04:03 PM |
| Cam gear and camshaft position sensor gear... | 99v6stang | V6 Mustangs | 17 | January 17th, 2008 03:00 PM |
| Does anyone use gear to gear timing? | e3sean | 5.0 Mustangs | 24 | December 27th, 2007 03:37 PM |
| Gear questions! | shadow98gt | 96-98 | 8 | June 12th, 2007 12:26 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 06:22 PM |
