Witch MSD Dizzy
Old October 22nd, 2006, 03:19 AM   #1
tag team's Avatar
tag team is on a distinguished road
Witch MSD Dizzy
im in the prosses of efi to carb convr all most have it all. but undecided on what dissy to use . already have the 6al box and the blaster duce coil
and i know for sure that i whant a mechanical device.
any body that has been in my flip flops i sure luv to here some in put on it
Old October 22nd, 2006, 11:22 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Get an MSD part number 8582. It comes with extra springs and weights to curve the mechanical advance to your liking. Good stuff.
Old October 22nd, 2006, 06:20 PM   #3
tag team's Avatar
thanks alot!!!! i have been looking thru just abought all of these and i see you just abought answer all them.. so i feel very confadent of you choise.
you also have a very sweet ride!!!!!!
all 4 one & one 4 all
Old October 22nd, 2006, 07:20 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've run that distributor many times. MSD makes good stuff.
Thanks for the compliments on the car!
Old October 22nd, 2006, 09:42 PM   #5
tag team's Avatar
yeah i have been told that the msd had problems being machined to be a tight fit and would break the pin on the gear just on the small blocks. i take it that you havn't had any trouble with them..do they come with a bronze gear or a steel one?
Old October 23rd, 2006, 12:02 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The problem with them is actually the retaining ring on the oil pump shaft. The MSD distributor has a slighty longer shaft which makes the gear hit the retaining ring on some engines. All you have to do is drive the ring down with a socket, extension and hammer.
Old October 23rd, 2006, 02:25 PM   #7
tag team's Avatar
thanks again!!!!!!!!
Old October 23rd, 2006, 08:57 PM   #8
Zak
Zak is on a distinguished road
As mentioned, MSD is the best, but a bit costly..
If that is an issue, you can get a Ford Duraspark II with a module.. check out this great website that tells you everything you need to know:
Jason Fletchers EFI Mustang to Carb. Conversion Tech
or you can get what I bought for my next project: a Summit Racing HEI (GM) style Mustang distributor that's got a vacuum advance & steel gears, and comes with the coil on top so you wont need any ignitions modules or anything else -just bolts it on-, for only $188:
Summit Blueprinted HEI Distributor
Old October 23rd, 2006, 09:14 PM   #9
tag team's Avatar
hey zac ! can i use my msd 6al box with that?
Old October 23rd, 2006, 09:21 PM   #10
Zak
I still havent tried that but I cant see why not -the 6AL ignition box will be hooked up to the HEI coil instead of a HVC coil- unless Darrell has an experience with it, I'm sure he does..
Old October 23rd, 2006, 09:23 PM   #11
tag team's Avatar
yeah im sure he has messed with it at some point!! thanks for tha info !!
Old October 24th, 2006, 11:12 AM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can use an MSD ignition with anything.
Threads Similar to: Witch MSD Dizzy
WITCH HEADS TO BUY?? mike96gt 96-98 20 October 8th, 2007 11:15 PM
WITCH GEARS? mike96gt 96-98 28 October 7th, 2007 11:22 PM
Bullet Witch for 360 joejoe8455 The Clubhouse 0 August 1st, 2007 03:23 AM
Witch car do u like better? Ticket-Me-Yellow V6 Mustangs 13 January 25th, 2007 03:02 PM
witch one ? superbeef1000 99-04 7 December 13th, 2006 02:41 AM
