Discussing 5.0 swap need wiring help ASAP!!! in the 5.0 Mustangs Forum. Greetings all, I am new to this site and am in dire need of help. ...
Old April 24th, 2008, 11:37 PM   #1
samstigg's Avatar
1992 Mustang LX
Greetings all, I am new to this site and am in dire need of help. I have just done a 2.3 to 5.0 conversion. I think I may have messed up on my choice for ECM and wiring harness. I swapped a 5.0 out of a 90' LX completewith ECM and engine harness into a 92' 2.3 LX, My problem is that i get basic power to the ignition (lights work, turn signals, Heater fan, etc.) however turning the key to the "On" posistion..the fuel pump does not prime,, then the key over to crank the motor..nothing happens. In addition when I turn my head lights on the horn blows along with the lights turning on.
Guys I need some serious help on this one!!!
Thanks in advance
Old April 25th, 2008, 03:09 AM   #2
FoxHoss's Avatar
02' GT
oh gosh, im doing this swap rite now, an 89 to an 89 tho... im swapping the ECM and related harness in the next day or so, hope you find hte problem. let me know if you find the problem so i dont go down the same path, good luck bro
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
'02 GT~dd
'89 LX~still in swap mode
'95 S-ten 4x4~winter beater
Old April 25th, 2008, 06:18 AM   #3
e3sean's Avatar
1988 lx 5.7
11.6@109
change the relay that is next to the computer. make sure the computer harness has a good ground. i just had the same symptoms and it was the ecu harness main relay next to the ecu
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331
MILITARY CREW
USAF LUKE AFB AZ,
E-5 SELECT 7995
AMMO I.Y.A.A.Y.A.S
Old April 25th, 2008, 08:41 AM   #4
samstigg's Avatar
1992 Mustang LX
Ithink you will be fine, using 89' to 89'. I think part of my problem might be the fact that I have a 92' an used the ECM and Harness from a 90', things changed a little between those years. I will check the power relay, it was swapped out in with the 90' haress, but maybe it was bad to begin with. any other ideas just in case??? what about the fuel relay??
Threads Similar to: 5.0 swap need wiring help ASAP!!!
Help Asap! Tiller88 5.0 Mustangs 21 February 8th, 2008 04:16 PM
carb swap wiring question notchabovechevy 5.0 Mustangs 14 February 3rd, 2008 08:08 PM
How to convert from a H3 bulb wiring to 893 bulb wiring? natedawgishot V6 Mustangs 0 February 2nd, 2008 01:04 AM
N/A wiring to turbo wiring 78mach1 2.3 Mustangs 2 January 22nd, 2008 09:03 PM
wiring harness swap? FoxHoss 5.0 Mustangs 8 October 27th, 2007 04:05 AM
