Discussing ? about internals in the 5.0 Mustangs Forum. i've read several posts here and elsewhere that claim the pistons in my car ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1986 Mustang GT
? about internals
i've read several posts here and elsewhere that claim the pistons in my car won't work with an aftermarket cam. any truth to this? i'm just wondering cause the guy i bought it from knew zero about the car and was no help as far as what was done to the engine. i found a list of mods a while back that the owner before had put in. Lunati Cam was one of them. didn't say anything about which cam it was though. but with a lunati cam, and edlebrock heads, would it be safe to assume that the internals aren't stock?
MILITARY CREW
AT2 |
1965 Mustang Fastback
you have flat top pistons which i guess run into problems when running different cam, heads
someone will come in here and tell you more about that im sure |
1989 Mustang LX
10.98@126.7 NA
I used an F-303 in an '86 GT motor with the stock '86 heads and a Trick Flow spring up-grade. That motor is still running around in a Ranger with no problems. I used head gaskets that were .042 thick and had the clearance needed. If you don't go bigger than that you should be fine.
Never fast enough.
#4 | |
1986 Mustang GT
MILITARY CREW
AT2 |
1989 Mustang LX
10.98@126.7 NA
Depends on which cam and which heads. Could still have a stock bottom end. The F-303 cam is .512 / .512 lift with 1.6 rockers.
Never fast enough.
#6 | |
1986 Mustang GT
and ".512 / .512 lift with 1.6 rockers" might as well be japanese. i'm not what you would call an aficionado.
MILITARY CREW
AT2 Last edited by Squints : April 25th, 2008 at 02:42 PM. |
Threads Similar to: ? about internals
| Internals | droppedbass87 | Poweradders | 23 | November 14th, 2007 04:35 PM |
| Forging Internals | DSG04GT | 99-04 | 14 | November 12th, 2007 12:00 PM |
| Internals | 01silversnake | 99-04 | 9 | October 17th, 2007 08:57 PM |
| new internals | bone_crusher | V6 Mustangs | 55 | October 3rd, 2007 05:35 PM |
| 01 GT Internals | MnrlGry01gt | 99-04 | 12 | November 13th, 2006 01:59 AM |
