Discussing Piston problem in the 5.0 Mustangs Forum. I started putting a set of heads on my car and discovered a series of ...
Old April 26th, 2008, 10:34 AM   #1
JBIGBOOTSY's Avatar
1990 LX hatch
Piston problem
I started putting a set of heads on my car and discovered a series of nasty marks, dents and craters on the surface of #3. I ground them smooth and lightly sanded over them. I think they were the culprit of a random part throttle pre ignition problem I have been having. When I'm done I'll head to the dyno and post resullts.
Old April 26th, 2008, 03:01 PM   #2
Hunt_chevs's Avatar
88 Gt
Not Slow
when doing my top end rebuild, i removed a gang of shit of my piston, cleaned them up to like new condition, and it solve many probs. i had.
let us know how it turns out,. im curious
Old April 26th, 2008, 09:09 PM   #3
fogged306's Avatar
89 GT
They also could have been the result of the problem you were having.
Old April 26th, 2008, 10:59 PM   #4
ryans88gt's Avatar
EGR?? If it isn't functioning, but the computer thinks it is, the computer bumps the timing during EGR function (part throttle) and it will cause pinging if the EGR isn't actually working. you can buy a little plug on ebay that tricks the computer into thinking the EGR is non-functional.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old April 27th, 2008, 12:32 AM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
I have an EGR delete plate. I finished it up and took it for a spin more power and no pre ignition. AND, my ghetto dremmel fly-cut pistons worked! I has a crowd over at my house for the initial start up, they were all making bets that it would blow up.
Old April 27th, 2008, 01:48 AM   #6
fogged306's Avatar
89 GT
The delete plate and the thing ryans88gt is talking about are 2 different things. The little plug that he's talking about plugs into the connector for the EGR.
Old April 27th, 2008, 02:05 AM   #7
JBIGBOOTSY's Avatar
1990 LX hatch
I realize that. I believe the thing ryans is talking about is the EGR simulator, I have no simulator, the trouble code is present so the system runs with the EGR function off due to no signal.
Old April 27th, 2008, 07:20 AM   #8
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Damn, i've never heard of this. I got FRPP gt40 lower witch does not have the hole for EGR, so i just left all other stuff untouched so that the CE-light stays off. But i haven't heard any pinging, could that be because i'm running on 93 octane?
Old April 27th, 2008, 01:46 PM   #9
ryans88gt's Avatar
But then your CEL is on all the time, so you could have any number of other sensors going bonkers and you would never know. It was only like $20 for the simulator.
Dremmel fly cut pistons?? I got my finger crossed for you, I hope you get that preignition problem fingered out.
88 GT 11.4 @ 118
Old April 27th, 2008, 02:54 PM   #10
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Just $20? Have to get me one ASAP.
Threads Similar to: Piston problem
2 piston calipers cj1220 99-04 4 March 16th, 2008 12:04 PM
Piston heads imported_Gt_Jay 5.0 Mustangs 23 January 22nd, 2008 12:01 AM
Whats the best piston to have? powersrj 5.0 Mustangs 3 August 21st, 2007 10:50 PM
having a problem depressing rear brake piston blue6er99 General Tech 5 June 19th, 2006 09:12 PM
PISTON ? 89GTCONV Engine 1 June 14th, 2006 10:44 PM
