Compatible explorer years
Old April 26th, 2008, 02:33 PM   #1
Hunt_chevs's Avatar
2002 Gt
Not Slow
wut year explorers are compatible for fox body parts.. same years? 87-93?
Old April 27th, 2008, 10:53 AM   #2
tmoss's Avatar
tmoss is on a distinguished road
be more specific about what parts you are looking to use off the xploder.........
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old April 27th, 2008, 04:34 PM   #3
Hunt_chevs's Avatar
2002 Gt
Not Slow
intakes
Old April 27th, 2008, 04:34 PM   #4
Hunt_chevs's Avatar
2002 Gt
Not Slow
maybe axles, brakes, etc
Old April 27th, 2008, 04:53 PM   #5
1965 Mustang Fastback
nba1341 will become famous soon enough
geads
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old April 27th, 2008, 07:46 PM   #6
tmoss's Avatar
The 96 or early 97 Explorer intakes have the same internal EGR passages (even though it used external ERG) if you need to stay emissions legal. mid-late 97 up have intakes with no internal EGR passage.
65mm TB can be converted easily to the Mustang, the 19# injectors are a straight across swap.
Old April 28th, 2008, 01:23 PM   #7
Hunt_chevs's Avatar
2002 Gt
Not Slow
Originally Posted by nba1341 View Post
geads
ive had my stock heads ported and chevy valves installed
Old April 28th, 2008, 01:28 PM   #8
Hunt_chevs's Avatar
2002 Gt
Not Slow
ok, for my next couple of questions.. Stock gt injectors are not 19#?
what needs to be done to install the explorer tb to work
and if im not worried about smog, how do i go about using the exploder intakes and doing away with egr..?
or can egr bolt directly to 96/97 intake thus allowing me use egr still.
and last but not least,will i notice any positive feedback doing and egr delete? (throttle responsiveness, gas mileage etc
Old April 28th, 2008, 01:57 PM   #9
tmoss's Avatar
You can use the 96 intake just like an HO intake with minor exception - the ACT in the #5 runner has to be drilled (19/32" or 9/16" will do) and tapped (3/8" NPT) to acceptr the ACT or you can extend the wiring and mount the ACT in the plastic section of the TB intake tube. Instruction for converting the TB for use on a Fox are on my website in the tech section.
Old April 29th, 2008, 07:35 PM   #10
Hunt_chevs's Avatar
2002 Gt
Not Slow
nice,.. so not much fab work is necessary? are the gains worth the swap? are explorer injectors the same as gt's?
Old April 29th, 2008, 09:50 PM   #11
tmoss's Avatar
yes and yes.
If you had the equipment and skills, a ported stock intake is a better match for E7, Ported E7, stock GT40 or Gt40P heads for a street/strip combo in my opinion.
Threads Similar to: Compatible explorer years
Are Eibach Federn 3510.301 Springs compatible for my 2001 Mustang GT? bzeboymenz 99-04 0 December 23rd, 2007 04:17 PM
Detroit Locker Compatible With C-Clip Axles? C MY 4D 4V / SVT 0 November 12th, 2007 07:25 PM
Upgrades compatible with supercharger? 95blueGT 94-95 6 October 5th, 2007 02:22 PM
Explorer heads, What years? roscoe 5.0 Mustangs 5 June 14th, 2007 05:44 PM
Only took me 19 years to get one. DarthShanka New Members Introductions 9 January 8th, 2007 12:24 PM
