EFI To Carb?
Old October 22nd, 2006, 08:44 PM   #1
88 stang gt is on a distinguished road
EFI To Carb?
i have a 88 mustang and i was just curious what i would have to do to make it carbed instead of the efi and if it is worth doin the reason i am interested is that my whole family is more into the carbs and they dont like messin with efi
Old October 22nd, 2006, 09:14 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Unless the engine is heavily modified you will be sorry. The EFI make alot more low end power for street cars. A carb on a stock or mild 5 liter engine will loose alot of low end.
Old October 22nd, 2006, 09:45 PM   #3
what about the other part of my question
Old October 22nd, 2006, 09:49 PM   #4
83 5.0's Avatar
83 5.0 is on a distinguished road
Just installed a 93 5.0 which was efi into my 83 convertible, with a carb and there are a couple of little things you have to do.
Pressure regulator for carb if using in tank fuel pump, distributor will need to be changed, I used a mallory unit, possibly coil may need to be changed, PCV is different than the efi type as efi's is built into lower manifold.. Had to make the throttle cable bracket, may even need to use a different cable (I had the old V6 unit to play with). If automatic trans there where some linkage issues mentioned in the edelbrock instructions for kick down etc., mine is 5 speed so no problems.
Do you need to meet emission regulations?, you may need the egr plate etc.
Heater hoses are plumbed a bit different as efi uses 2 steel tubes which sit on the manifold, but interfered with my edelbrock carb linkage.
All I can think of, hopefully not too discouraging.
Old October 22nd, 2006, 11:06 PM   #5
im five speed to and no i do not have to meet emissions... but im looking in long run performance wise is it worth it and how much cash are we talking abot for this conversion just a ball park so i can compare
Old October 23rd, 2006, 10:57 PM   #6
83 5.0's Avatar
I bought all new intake, carb and edelbrock performer intake maybe around $700.00, check out www.mustangsunlimited.com/ for some on line pricing.
Old October 24th, 2006, 12:59 PM   #7
HORSMEN1995 is on a distinguished road
i am also considering this option when i rebuild. i have a 95 GT HO_5.0 which i am going to stroke out to 347, and i dont want the efi, it is not going to be a street car, just a drag car, im hoping to make somewhere upwards of 470-500 hp. will switching to carb be efficient for my application?
Old October 25th, 2006, 12:02 AM   #8
shockashark's Avatar
shockashark is on a distinguished road
Just read this post so I thought I would chime in:
I am currently in the process of conversion here is my hit list and I am doing my best to keep it cheap, but do it right:
HLY-0-1850S ST Carb 600 Vac Sec - Silver $211.03
OFY-5691 MANIFOLD $211.10
SUM-239000 1/2 INCH AIR CLEANER SPACER $2.60
SUM-G1423 CARB STUD KIT 3/8IN $5.39
SUM-G2420 GSKT INTAKE SBF $5.39
SUM-G3001 14" CHROME AIR CLEANER W/LOGO $14.44
Ebay - FORD 302 DISTRIBUTOR HEI w/ coil on top $57.50
Will try to fabercate all my little odds and ends like throttle cable, fuel connection etc... The only issue I believe will be the cams not sure if the rebuild that was done replaced the stock cam so there may be an issue with the HEI Dis. but will wait and see... Will see about posting pic's kinda new to this but it is fun none the less.
My big reason for doing this is I am not a fan of computers or electrical parts, they always seem to break around me...
Old October 25th, 2006, 03:32 PM   #9
sn-95aac's Avatar
sn-95aac is on a distinguished road
i agree. if you want to put that much power consider fuel injected!!
95 TURBOCHARGED COBRA
87 BLOW-THRU FOX
Old October 25th, 2006, 03:50 PM   #10
OTreborO is on a distinguished road
All I can think of is Why??????????
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old October 26th, 2006, 12:47 PM   #11
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
what about a pressure regulator and fuel lines. :wink
There's a reason Ford codenamed them the Terminator
Old October 26th, 2006, 09:02 PM   #12
Oh ya... Almost forgot you need to get fuel to the motor... Oh well this little fix is going to reach $700 quick... Now I gotta get a fuel pump and pressure reg... Welp may as well get a new tank pickup... There goes another $100... Better yet, fuel cell... woowoo... Which fuel pump and reg. is better bang for the buck ???
As this is going I may as well drop the $7000 and go get a worked motor from http://proformanceunlimited.com/ford.html Maybe next year...
Threads Similar to: EFI To Carb?
CARB OR EFI BLACKNIGHT5.0 94-95 10 August 16th, 2007 04:39 PM
efi to carb please help itsmyfiveoh 5.0 Mustangs 33 June 20th, 2007 03:26 PM
carb to efi 347tt 5.0 Mustangs 5 February 11th, 2007 09:08 PM
carb ? terribleonexx88 5.0 Mustangs 11 December 4th, 2006 02:21 AM
V6 EFI vs Carb quikstang2 V6 Mustangs 3 August 17th, 2006 07:19 PM
