Discussing Misfire under load in the 5.0 Mustangs Forum. Two days ago my LX started misfiring. It does it when I'm accelerating, usually ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Badass Mother 3000
Twice as fast as your ass!
Misfire under load
Two days ago my LX started misfiring. It does it when I'm accelerating, usually between 3 and 4000 rpm, or when going uphill. When I got home I changed the plugs (went with NGKs gapped at .045. The Autolites I took out of it were gapped at .040 and I thought that was kinda tight, they came in the car.) It has newer MSD 8.5 wires with an MSD Blaster EFI coil. MSD 6al with an MSD cap on a Motorcraft distributor.
After I changed the plugs I noticed it runs a little nicer. It misfires less, but it still does it occasionally. I did pretty much a whole tune up on it and cleaned and inspected the MAF and thottle body, also ran injector cleaner. Everything seems good but it still misfires occasionally. Then I thought maybe moisture in the fuel lines so topped it off and put some water remover in it. Before this the car ran smoothly and gave me 0 problems. Could it be that I got ahold of some crappy fuel or is there something I might be overlooking? |
valve that needs to be adjusted
bad/weak coil switch the coils and see if the misfire changes cylinders main things that pop into my head |
1993 Lx
Skittle fast
timing advanced? running premium if it is?
![]() Greatest fail of MM's history http://www.moddedmustangs.com/forums...icer-page.html |
Badass Mother 3000
I kind of overlooked the coil because it's less than 2000 miles old. I'll have to see if I can dig up a spare and see how it runs. And I only run premium in it.
1993 Lx
Skittle fast
arent coils either good or bad with no in between?
also check to make sure that the wires are seated on the spark plugs
if one of the boots isnt seated right it can cause it to misfire occasionally i had this happen to a friends car this weekend, boot wasnt seated properly and the spark was going to the header instead of the plug haha |
1982 Mustang GT, SVT Swap
Also make sure that your 7 and 8 cyl plug wires are not next to each other they can cause a miss due to wire voltage seepage since 7 and 8 fire so close together.
I don't know about 7-8 specifically but I fixed a random misfire by organizing my plug wires.
1991 GT - Original owner, all stock 1988 GT - The project car |
I have an instructor that works at ford as a mechanic and that is what he said that if you get plug wires 7 and 8 to close it will cause a miss . . . Glad you got it fixed.
1993 mustang lx convertib
check the ignition moduel i had problems like that chnged it out and it went away
Threads Similar to: Misfire under load
| A load hum | Blackblurr_00GT | 99-04 | 2 | February 20th, 2008 02:22 PM |
| misfire | riddlee josh | V6 Mustangs | 20 | January 19th, 2008 10:41 AM |
| pinging when under a load | cobraetti | 5.0 Mustangs | 4 | April 28th, 2007 11:42 AM |
| 86 stumbling under load | hopper | 5.0 Mustangs | 6 | April 25th, 2007 10:25 PM |
| misfire.... | stang fanatic | General Tech | 10 | June 23rd, 2006 11:08 AM |
