Discussing 2500 Stall Be Fine in the 5.0 Mustangs Forum. my car allready had the c4 trany with the reverse valve body and a trans ...
Old October 22nd, 2006, 08:51 PM   #1
tag team's Avatar
2500 Stall Be Fine
my car allready had the c4 trany with the reverse valve body and a trans break but no damn staal . before i took my efi off i took it to the srtip. piss poor hole shot !! my 60ft times are just to damn high. i whant my font tires to leave the ground. if i get my car to that ill be tikeld pink fellas.
give me some info pls. thanks
all 4 one & one 4 all
Old October 23rd, 2006, 01:05 AM   #2
Tony_90fox's Avatar
if you really want just a strip car, maybe a higher stall is needed but that is what i am putting in my car. it will be about 50/50 though, but used alot on the street.
Suck on it Trebek. Suck it long, suck it hard.
Old October 23rd, 2006, 01:37 AM   #3
smbikes's Avatar
The stall is all about the type of motor u have (what type of cam+head+intake= what rpm the power really come in ) and what the car will be used for , such as street/strip or just strip , then what type of converter (lock up or nonlock up) ,then weather or not u are spraying also plays a part ( tight coverter and antiballon plates) , give the guys a call at edgeracingconverters.com a call and tell them what u have and what u want and they will set u up .
302 ci bored 40 over converted to carb, comp cams XE274HR cam .555/.565 lift, much more , dyno'd at 471.8 HP @ 5700 RPM!!
Old October 23rd, 2006, 10:50 AM   #4
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Need more info. Engine specs, vehicle weight, gearing, etc.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old October 23rd, 2006, 01:18 PM   #5
tag team's Avatar
its 90 gt just guted the fuel inject .. i put a torker intake the old school one with the carb is sitting in a turn .a 650 holy dbl pump going to put all msd .the gears are 373. the cam that is in it i dont know it was all ready up greated when i got it . it has a good hit to it. the car was super charged before i got it so i think that the cam is still the same one when it was on it. when i ran it on the 1/8 my power started around 2000 to 2500 rpms. yall fellas might have a better idea of what cam is in it. it will be street & strip
Old October 23rd, 2006, 07:58 PM   #6
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
What kind of heads are on it? Without knowing what the cam specs are it will be really hard to accurately pick a torque converter.
Old October 23rd, 2006, 08:33 PM   #7
tag team's Avatar
stock heads
Old October 23rd, 2006, 08:37 PM   #8
tag team's Avatar
hey darrel i seen were you have a nos plate from edelbrok. will a super power shot system hook up to that? and also the purge hook up to it also?
Old October 24th, 2006, 10:11 AM   #9
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by tag team
stock heads
2500 will be fine. With stock heads you aren't going to make any big horsepower numbers so don't get your hopes too high for your "front tires leaving the ground".
I had an Edelbrock plate system. I sold it. It was a complete kit so no a power shot system wouldn't hook up to it. It did have a purge.
Threads Similar to: 2500 Stall Be Fine
dodge 2500 scxc15 Drag 7 September 28th, 2007 07:44 PM
fine example of cobra wheel-hop WilltheThrill Videos 5 June 5th, 2007 02:07 AM
midly built AOD with 2500 stall SALIV8 For Sale 5 April 23rd, 2007 10:47 PM
2500$ notsoslo5.0 5.0 Mustangs 14 February 21st, 2007 01:34 PM
Alignment out of whack on a perfectly fine Roush Stang OZ Suspension 2 August 29th, 2006 03:08 AM
