Cam for a mostly stock 5.0 ?
Old April 28th, 2008, 09:38 PM   #1
blakehunter316's Avatar
1989 Mustang GT
14.01 @ 103..... :(
blakehunter316 is on a distinguished road
Heard a old ford coupe with a 302 in it with a mild cam sounded really good. i have no motor work and was lookin to get a upper and lower intake in the future, but is there a good performing cam that has a bit of a lope and make some more power? everyone says stock cam is good but just lookin for a little more.
vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er
Old April 28th, 2008, 09:41 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
custom grind.
Old April 28th, 2008, 09:55 PM   #3
1989 Mustang GT
14.01 @ 103..... :(
i been hearing about that just cause i'm still learnin the more complex part of the whole motor thing tell me how to get that done. lol stupid question prolly thanks ...
Old April 28th, 2008, 11:36 PM   #4
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
Companies like flowtech inductions, comp, etc have sheets you fill out with the specifications of your motor and you tell them your goals, wants, and needs and they spec you out a custom cam....from what i have heard a cam in a stock 5.0 adds little performance(i may be wrong), unlike the LSx motors!
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Old April 28th, 2008, 11:55 PM   #5
fogged306's Avatar
89 GT
Originally Posted by JBIGBOOTSY View Post
custom grind.
On a stock motor?
A custom grind cam is going to be the best suited cam for a given application, but it will cost you more. If you are going to do an engine right, get the heads, intake, ect.. before you do a cam. Then do a custom grind, so you only have to do it once. When they build you a cam, they ask you a lot of questions about the car and the about the engine its going in, weight of the car, trans, gearing, ect.. and build the cam to suit. If you get a custom grind now and then change things around later, your cam won't be set up perfectly anymore.
Old April 29th, 2008, 12:22 AM   #6
1965 Mustang Fastback
nba1341 will become famous soon enough
A cam will make a big difference with matching valve springs.
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old April 29th, 2008, 01:20 AM   #7
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I would just get a letter cam or a trick flow stage 1 for a fairly stock motor. Combined with an aftermarket in take you will see a improvement in power. I have a friend that has a f cam in his and it runs really good and sounds tough .
Old April 29th, 2008, 01:42 AM   #8
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
if your keeping it relatively mild then i would suggest a letter cam
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old April 29th, 2008, 06:07 AM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
Originally Posted by fogged306 View Post
On a stock motor?
I was makin a funny.
Old April 29th, 2008, 06:29 AM   #10
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
If you don't have a big budget, go get yourself an f303 cam which is about 189 bucks. Then get the 93 cobra upper and lower intakes for now. You will see nice gains in that combo... then down the road get some heads.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old April 29th, 2008, 09:56 AM   #11
fogged306's Avatar
89 GT
Yea.. I should have figured that.. it was late last night when I wrote that.. thats my excuse and I'm sticking to it.
Old April 29th, 2008, 04:28 PM   #12
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
Don't bother getting a cam until you get everything else for the engine... heads...intake etc.... then you can pick a good cam to work with everything or get custom cam when your done doing all day..
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
Old April 29th, 2008, 05:27 PM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
A good cam and intake combo won't give you the gobs of power that some might think, but it will give you some. more importantly it will move your powerband up a bit in the RPMs.
Old April 29th, 2008, 10:19 PM   #14
1989 Mustang GT
14.01 @ 103..... :(
so if I don't get into the heads is it worth it to go with a cobra upper and lower and a cam or maybe a trick flow upper and lower and cam ?
Old April 29th, 2008, 11:06 PM   #15
ridebmxfbm's Avatar
I would just get the cam once you have everything else... so that you choose which is the best cam for your application when its done..
Old April 29th, 2008, 11:41 PM   #16
1989 Mustang GT
14.01 @ 103..... :(
I just don't think i'm goin to ever get into the heads on it is my problem cause first i only have about 800 saved up right now and thats not enough for an h/c/i kit and i want to lower it a little and get other stuff so i just was thinkin if up and lower intake and cam would work good with out heads.
Old April 30th, 2008, 05:36 AM   #17
JBIGBOOTSY's Avatar
1990 LX hatch
you could by used stuff. I happen to have laying around gt40ps, pp typhoon intake c&l maf for 24# inj., 24# injectors, 65mm TB, fenderwell intake. adj. fuel pressure regulator. EGR delete.
Old April 30th, 2008, 10:21 AM   #18
baine21225's Avatar
same your money on a cam for last
Old April 30th, 2008, 06:05 PM   #19
1989 Mustang GT
14.01 @ 103..... :(
Like happen to be selling it ? If so how much would we be talkin for it all ? Minus the c.a.I
Old April 30th, 2008, 08:31 PM   #20
JBIGBOOTSY's Avatar
1990 LX hatch
Any reasonable offer.
Threads Similar to: Cam for a mostly stock 5.0 ?
Biggest cam in a stock 5.0? wesbeck632 5.0 Mustangs 37 April 9th, 2008 09:43 PM
performance cam/stock heads? 1990CA50 5.0 Mustangs 17 February 6th, 2007 01:02 PM
Stock Cam cali 5.0 Modular Mustangs 1 November 7th, 2006 02:00 PM
Stock Cam Quiestion? Mustang8719 5.0 Mustangs 5 June 26th, 2006 07:15 PM
