? Speed density and cams will it work. - Forums at Modded Mustangs
post #1 of 26 Old April 29th, 2008, 07:29 AM Thread Starter
Will a 89 5.0 with a E303 cam and ported heads run on speed density? any way.
MARK420 is offline
post #2 of 26 Old April 29th, 2008, 09:50 AM
I believe it should, the only thing is its expensive to "tune" b/c its not a computer or anything and apparently it takes more time. A guy told me it can cost up to $500, dunno if its true or not though.
But depending on if you can or not, i would try to get my hands on a MAF harnest out of maybe a junker mustang 89-93 or maybe something on ebay and convert it over. Its worth it you will get more proformance out of your ride, plus if ya ever do anymore mods down the road it would prob be a good idea to convert it now if ya can, in the long run its cheaper.
The Novice is offline
post #3 of 26 Old April 29th, 2008, 09:57 AM
2008 Hammock Rodeo Champ
Squints's Avatar
Send a message via AIM to Squints
it should have the MAF setup already. '89 was the first year.
i have no mustang. so don't listen to anything i say.
Squints is offline
post #4 of 26 Old April 29th, 2008, 09:57 AM
ridebmxfbm's Avatar
89 was mass air.. not speed density and the 3 cam will not work with speed density but there are other cams that will but your car shouldnt be speed density if its 89
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
ridebmxfbm is offline
post #5 of 26 Old April 29th, 2008, 09:59 AM
Squints's Avatar
are you wanting to convert to speed density from MAF? if so... why?
Squints is offline
post #6 of 26 Old April 29th, 2008, 11:59 AM Thread Starter
Try to get speed density to work with my cam . car is a 88 not a 89 .
MARK420 is offline
post #7 of 26 Old April 29th, 2008, 12:55 PM
ridebmxfbm's Avatar
alright just making sure.. and theres no way that the e cam will work... but some cams will.. also do u have anything else done to it?
post #8 of 26 Old April 29th, 2008, 01:37 PM
fogged306's Avatar
Change over to a MAF setup and save yourself the headache.
fogged306 is offline
post #9 of 26 Old April 29th, 2008, 05:25 PM
ridebmxfbm's Avatar
you dont have to change over... you can either get 1.7rr with the stock cam and that should help or you can just choose a cam that will work...
the cams in green will work good, and the cams in red or orange will need some tuning... a good all around cam for SD would be the crower 15511 cam, but if you want it to sound lopey forget about it with SD its not gonna happen maybe only a little bit but not much
post #10 of 26 Old April 30th, 2008, 09:27 AM
tmoss's Avatar
you will have idle issues with an E more than likely but good WOT performance
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
tmoss is offline
post #11 of 26 Old January 23rd, 2010, 01:01 PM
Would this crower 15511 cam work on a 5.8l SD?
Tyler2009 is offline
post #12 of 26 Old January 23rd, 2010, 01:31 PM
tmoss's Avatar
yes, it will be even milder in a 351 - use the 1.7 rockers if you can. The 15512 would also work in the 351.
tmoss is offline
post #13 of 26 Old January 23rd, 2010, 01:35 PM
just spend the money now and switch to MAF if you plan on doing much more work to it in the future.
1988 vert - 336ci, TF 205cc fully CNC'd, AFM N-71 with matching springs, 1.6 roller rockers, TF R-series intake, 75mm TB, 75mm MAF, loads of other useless parts
2004 F250
88Saleen is offline
post #14 of 26 Old January 23rd, 2010, 03:36 PM
I am looking for help on the cheapest way to do it could you help me?
post #15 of 26 Old January 23rd, 2010, 03:53 PM
The Big Spoon
jessemachone's Avatar
got to the yard and get a maf and computer. do the conversion and you will no nonger be limited by speed density.
Mass Airflow Conversion - Muscle Mustangs & Fast Fords Magazine
jessemachone is offline
post #16 of 26 Old January 23rd, 2010, 04:07 PM
I dont have a mustang i have a van but it has the same engine as the 94-95 F150 SD my van has the 5.8l with the E4OD.
post #17 of 26 Old January 24th, 2010, 04:03 AM
FastStang91Lx's Avatar
Maybe some didn't notice... He revived and old thread.
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #18 of 26 Old January 24th, 2010, 05:08 PM
So can anyone help me on this subject?
post #19 of 26 Old January 25th, 2010, 02:45 PM
tmoss's Avatar
you asked a question and you got an answer..........
tmoss is offline
post #20 of 26 Old January 25th, 2010, 03:15 PM
PSN alphadong11
dr.gonzo!'s Avatar
The cheapest way would be to go with 1.7 rockers. People have been in the 11's on the stock cam and didn't have to go through the BS of changing it out, you save money cause you didn't have to buy the cam or the MAF kit. Get a set of decent heads and an intake for relatively cheap or save more money.
dr.gonzo! is online now
Human Verification
