Compression Question
ok...Im looking at getting a st of gt40p's this weekend...the thing is they are milled .060 I was wondering what the compression bump would be...and if i would still be alright running the juice with the upped compression.
![]() 95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete BOOSTED |
12.8@103... stock motor
11.8@113...150 shot
i offer no help with the juice, but it probably bumped your compression up to 10.5:1 if you dont have high compression pistons.
i think for every .03 its milled, it ads .05 Last edited by R0B0T; April 29th, 2008 at 03:54 PM. |
89 GT
It doesn't matter what compression ratio you have for nitrous. As long as you have enough fuel and pull a little timing, you will be fine.
1990 LX hatch
.060 mill will give you 2 really big paperweights.
![]() haha that sucksss
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
#6 | |
95 opalfrost gt
+1 Nitrous isnt affected like boost when it comes to compression. Just make sure your tune is on and you will have no problems.
1987 Mustang GT
I don't think you will be near 10-1 with the heads milled like that. Just be careful because when they mill a ton off the heads sometimes the intake wont fit properly.
heh. guess i wont be purchasing them...One more question...What head gaskets do i use with the p's?
1965 Mustang Fastback
does this mean he has to run 93 octane?
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
1990 LX hatch
1990 LX hatch
So just regular 5.0 head gaskets then.
1986 mustang gt convert
60 over wont he need the intake to be angle milled
went a diff route
Big timin' in a small town
Man I love this guy
Reps JbigWhere you been go in the clubhouse I miss you
1990 LX hatch
my 540 motor is 13to1 compression,I use 200 hp. nitrous.. with o-ring block and copper head gaskets... head studs
Threads Similar to: Compression Question
| Compression | 87StangLX | 5.0 Mustangs | 20 | March 8th, 2008 01:35 PM |
| Compression and timing question | suds488 | 96-98 | 6 | January 14th, 2008 12:04 PM |
| A Question About Prochager With High Compression | blue03mach1 | 99-04 | 15 | November 9th, 2007 02:46 PM |
| compression | greenstallion | 99-04 | 4 | March 8th, 2007 06:40 PM |
| Question On Compression | chadjones99 | 5.0 Mustangs | 4 | September 12th, 2006 11:24 AM |
