Just ordered BBK CAI from summit I got a question
Old April 29th, 2008, 04:05 PM   #1
White 89 is infamous around these parts
I just ordered a BBK CAI from summit.
Going to install it this weekend.
I don't have to do some sort of tune after I install it do I.
It should run fine after the install right. I won't notice any surging or it trying to die on me will I.
Also does the CAI make a sucking noise when I go thru the gears.
1989 mustang GT 5.0
Old April 29th, 2008, 04:06 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Nope. your good.
It should run fun. if it surges you have a leak and need to check all your fittings.
yes that can do that.
Old April 29th, 2008, 07:06 PM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
You will be fine I put a jlt cai on mine before I got the s/c and I didn't have any issues. I was able to notice a difference on my car nothing huge but a little snappier
Old April 29th, 2008, 07:16 PM   #4
Hunt_chevs's Avatar
2002 Gt
Not Slow
it'll run fine.. and yes it will probably make a sucking noise from the intake charge.. lots of fun when your next to people at lights.. blip the throttle kinda hard really quick and people will snap their neck trying to peep game on whats going on
Threads Similar to: Just ordered BBK CAI from summit I got a question
BBK CAI question sstang 99-04 21 April 29th, 2008 07:21 PM
Question About Summit Products MineralGreyGT 99-04 9 December 7th, 2007 02:36 PM
BBK CAI help AndrewA. 99-04 3 August 14th, 2007 02:35 PM
Question about Summit RyanHNT Vendors 4 June 25th, 2007 01:19 PM
Just Ordered The Gears On Summit! GTSilver 99-04 23 October 3rd, 2006 10:41 AM
