Something wrong. Please HELP!
Old October 23rd, 2006, 07:39 PM   #1
1990 HATCH
12.56@118
Mikes88 is on a distinguished road
I have an 88 GT and I relaced the TFI module twice only a few hundred miles ago. The car is now having the same problems by cutting out, and sometimes just not starting. SO do I replace it again or could a bad distributor be causing all of this? Please help!
Old October 23rd, 2006, 07:52 PM   #2
88Horseman is on a distinguished road
Pull your codes and see what it tells you. You may have a bad ECT or ACT
Old October 23rd, 2006, 08:33 PM   #3
1990 HATCH
12.56@118
Thank you, but I don't know what ECT or ACT means or are.
Old October 23rd, 2006, 09:49 PM   #4
ECT is your Engine Coolant Temp Sensor and ACT is the Air Charge Temp Sensor. It helps the engine computer to regulate various ignition, fuel and emission control functions, and to turn the radiator-cooling fan on and off as needed. The Air Charge Temperature (ACT) sensor is a thermal transistor, which means it allows less electricity to pass through the sensor the warmer it gets. It receives the “Signal Return” voltage from the EEC, and then allows a certain amount to return back to the EEC.
Threads Similar to: Something wrong. Please HELP!
What Is Wrong With My Car? 94pacecarSVT 94-95 10 November 10th, 2007 02:14 AM
You're Doing It Wrong... Onemanzu The Clubhouse 53 October 22nd, 2007 11:33 PM
Was I wrong??? JASonic The Clubhouse 32 October 18th, 2007 01:33 AM
something is wrong caintcatchmyGT 96-98 5 October 11th, 2007 11:14 PM
what else can go wrong? WAVEBYE The Clubhouse 17 January 29th, 2007 01:33 PM
