Trick Flow Top End Kit
I have seen these that come with upp and lower intake, heads, cam, timing chain,roller rockers, etc. Has anyone bought one of these? What is the power increase? And i have a 95 but all of them are for the up to 93's. I think the inly difference is the throttle body elbow. Anyone know for sure?
Thanks peeps Ford racing also has one of these kits. Which yeilds more power?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1986 mustang gt convert
good set up..cant use domes unless there trick flow. and with the twisted valves chambers you need to make sure you have right pistons even on flats. check ptv.. they make good power..edelbrock is good also with there new heads and roller cam..afr is good heads.. rhs is great also
1992 Lx
11.39@119.24
it will work on your car, just since yours is a 94-95 its gona run like complete shit until you get a dyno/tune
13.64@101mph
it is a good kit worth about 350hp...supposidly but prob in the 325hp range...way better than the ford racing kit...
Threads Similar to: Trick Flow Top End Kit
| Trick Flow Top End Kit | dr.gonzo! | 5.0 Mustangs | 20 | April 2nd, 2008 12:19 PM |
| Trick Flow Top End Kit | kpoirot | 94-95 | 10 | January 25th, 2008 03:09 PM |
| Trick Flow top end Kit | imported_Gt_Jay | 5.0 Mustangs | 0 | November 28th, 2007 07:52 PM |
| Top End Kit AFM or Trick Flow | rvdooley | 5.0 Mustangs | 5 | November 12th, 2007 06:22 PM |
| Trick Flow Top end kit. | Timm10221 | 5.0 Mustangs | 23 | October 17th, 2007 02:36 PM |
