low rpm miss
Old April 30th, 2008, 02:46 PM   #1
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
low rpm miss
so i have about 330 miles on my 88gt rebuild
if i lug the motor along it usually misses a few times then it seems like it hits the powerband and takes off. it only does this at low rpms i havnt gone past half throttle yet so i dont know how it is on top end.
i also set the cam 4deg advanced and have the timing at 13-14 deg and it pops and backfires occasionally should i have my timing at 10deg or what?
i have new plugs in it with msd wires, no air pump or smog(if that makes any diff) the cap and rotor are pretty new, stock coil
i know i need new o2 sensors could this be the cause?
also its just drinkin gas. i got about 100 miles on half a tank without ever going past 3k rpms.
Old April 30th, 2008, 07:03 PM   #2
MIGHTYJO3YOUNG's Avatar
1992 mustang Lx
13.4@ 106
MIGHTYJO3YOUNG is on a distinguished road
having bad o2 sensors will deff eat ur gas up
Old April 30th, 2008, 07:16 PM   #3
1992 Lx
11.39@119.24
gas mileage sounds pretty average to me
Old April 30th, 2008, 07:24 PM   #4
1992 Lx
11.39@119.24
and did you put the little plastic caps back on the injectors? my old ones didnt have them and did that
Old April 30th, 2008, 10:33 PM   #5
Bigfatts's Avatar
Badass Mother 3000
Twice as fast as your ass!
Bigfatts is on a distinguished road
I had a similar problem with me 331 powered LX, just got it fixed. I did new wires, cap/rotor, plugs, coil. Turned out to be the distributor. Lots of people rebuild engines, almost no one rebuilds distributors. Got the old one out and it was just a rattle trap about to come apart. $59 later and a reman distributor from Advanced and I now have my timing 11* advanced (the way the distributor was it threw off the timing, took alot of fiddling to get it right) and it runs like it's old self.
Old April 30th, 2008, 10:47 PM   #6
mxnate116's Avatar
SVTfocus, F250
yeah i didnt put new caps on the injectors just new o-rings.
and i wanted to rebuild the distributor cause i thought it seemed a little loose. i think ill do that now and get a msd coil.
now that i think about it that seems perfect cause my car hasnt seemed consistent in the way its driven since the rebuild.
Old April 30th, 2008, 10:48 PM   #7
mxnate116's Avatar
SVTfocus, F250
also could the TFI module have anything do to with it?
Old May 7th, 2008, 01:16 PM   #8
1986 mustang gt convert
86gtconvert is on a distinguished road
what cam ya have and tranny,any stall, could be timing..to many variables..what did ya have done to your motor
Old May 7th, 2008, 03:43 PM   #9
Speedstang302's Avatar
13.64@101mph
yeah what cam are you doing..really with anything less than the f303 cam i would just do 10-12*....f cam and up should be set 13/14*+
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old May 7th, 2008, 06:28 PM   #10
mxnate116's Avatar
SVTfocus, F250
5speed
stock cam
mild port job on the intake
msd wires
catless h pipe
NO mass air
bored .020 over
it doesnt seem to be doing it as much but it still happens occasionally
Old May 7th, 2008, 08:38 PM   #11
chase's Avatar
1987 Mustang LX
chase is on a distinguished road
Send a message via AIM to chase
I had a similar problem. It turned out to be my EGR valve. It was stuck open.
1987 LX 5spd 306 F cam 3.55 gears slicked
plus all the bolt on's
Old May 7th, 2008, 11:36 PM   #12
Vamp89's Avatar
1989 Mustang GT
Vamp89 is on a distinguished road
Mine also pops at low rpm's dunno why and just put new o2's on and it got better but it's still there.
Ported Saleen Vortech Intake
BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump
Hooker Super Comp Long-tube Headers
Fcam
Ported Motorsport J302 Heads
30# Injectors
1.6rr
80mm Mass Air
4:11 gears
Threads Similar to: low rpm miss
High Rpm Miss cptkng79 5.0 Mustangs 9 April 28th, 2008 06:36 PM
Please Help With High Rpm Miss cptkng79 5.0 Mustangs 8 October 1st, 2007 08:54 PM
Low rpm miss Badasstang281 99-04 3 March 22nd, 2007 02:48 PM
V6 RPM Miss (Temp Dependent) Plz Advise! Garman91 V6 Mustangs 34 January 17th, 2007 10:01 AM
Slight Miss When In High Gear / Low Rpm built54 Modular Mustangs 10 October 15th, 2006 11:22 PM
