Discussing Will stock block hold up? in the 5.0 Mustangs Forum. Originally Posted by Iownastang You would haft to build a car to see what all ...
Old April 30th, 2008, 10:20 PM   #21
DeMello's Avatar
01 nitrous injected GT
12s next time out...
Originally Posted by Iownastang View Post
You would haft to build a car to see what all goes into it. Theres alot of things that you would never dream of.
could u give me some examples of wat else goes into it and how much extra its gonna cost me then a kit?
NX wet kit, heater, purge, FPSS, window switch
PLX DM-5 wideband, raptor shiftlight, msd tach adapter
FRPP 410s, JLT CAI, STEEDA tri-ax, SCT x cal 3
STEEDA catback, SLP Loudmouths, UPR o/r X
NITTO Drag Radials, Zoom racing clutch
Old April 30th, 2008, 10:21 PM   #22
probably blow it up
Old April 30th, 2008, 10:23 PM   #23
1987 ford mustang gt
well see when shes done
Originally Posted by Blown331 View Post
The main reason to go with Nitrous and a blower at the same time is not a bad idea. Go with like a wet 75 shot. The reason for doing this is two fold. One-you are taking cold air and compressing it through the blower-we all know when you compress air it gets hotter than normal and then you are sending hot air into the intake. 2-it keeps you from having to run an intercooler/aftercooler and IMO can be more efficient. I am considering this because of that. It really isnt another power adder because all you are doing is cooling the air down when it reaches the combustion stage.
Also. How many miles are on the blcok? Was it modded at all. I know someone right now runnig 9.80's on a stock block with a 76mm turbo. Its a 306 so there is still plenty of block there. I would consider one thing. Your block may be worn down and if it is then you are taking a worn out block and seriously reducing the walls in the block to go with a 347. Go with a 331 if you want to do that.
What the Hell are you talking about "YOU ARE SERIOUSLY REDUCING THE WALLS GOING WITH A 347?? A 306,331.AND 347 ALL UTILIZE THE SAME BORE.
AND NITROUS IS NOT ANOTHER POWERADDER?
AND AS FOR YOUR FRIEND HE HAS A TICKING TIME BOMB.
Old April 30th, 2008, 10:28 PM   #24
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
Use a 351w block, your way better off. Hell if you have the money buy a siamese bore 351w block from ford racing, then you'll be set!!
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old May 1st, 2008, 01:16 AM   #25
FoxHoss's Avatar
02' GT
peicing a kit together would be more efficient with a s/c, for ex, a custom blower cam instead of the one that comes with the TF kit would be best. when you use a regular cam the valve overlap is going to be fighting the s/c in a way. get a blower cam, you get the lift/duration and whatnot but not nearly as much valve overlap so you can maintain whatever psi you use...
P.S. +1 with the 351w block, wayy more reliable and easier to make power, plus basicaly a bolt in swap... minus some small stuff
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
'02 GT~dd
'89 LX~still in swap mode
FOR SALE: Canfeild cylinder heads 302ci 2.02-1.60 valves 54cc combustion chambers-dual vavle springs $1200
Old May 1st, 2008, 04:23 PM   #26
ryans88gt's Avatar
nitrous and blowers work well together. Nitrous provides the low end grunt and the blower provides the top end charge. I gained 80 ft/lbs of torque at 2500 rpms from a 50 shot of N2O on top of the blower. That resulted in a torque curve that was over 400 ft/lbs from 2500 rpms to redline with a peak of 497 ft/lbs. Not bad for a little 302.
Although a factory block may last for a long time at 500 hp or above, there are no guarantees at that hp level.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old May 1st, 2008, 04:38 PM   #27
Goblin's Avatar
Secret In The Works
Dont worry about overheating really. I have a V2 S Trim and it works great. The problem is that superchargers get heat soaked right at the motor and the intercooler is a good idea but does not work as well as Nitrous. Also you are compressing air so fast that it hats up at the supercharger so the intercooler becomes useless at that point. An aftercooler would be an idea though. I mean would be pretty efficient as well.
Maybe it would be a good idea if you stop posting. Actually, it would be a good idea. Stop talking.
Definition of Fast?
I'd say thats good enough.
NMRA Outlaw 10.5 Season Opener 2008
Photo courtesy of - Yours Truly
Old May 1st, 2008, 04:50 PM   #28
2003 GT
Street Fast 16.9@76MPH
A small shot will make a blower so much more efficient that it's not even funny. There are virtually no reasons not to run N2O with a blower other than engine life if you don't build it right.
Old May 1st, 2008, 05:15 PM   #29
ryans88gt's Avatar
I can think of one other reason. A nitrous backfire will take out your head unit. But using a plate kit with a small shot you have a pretty low chance of a nitrous backfire.
It is really a matter of can the block/pistons/headgaskets take it.
88 GT 11.4 @ 118
Old May 1st, 2008, 07:06 PM   #30
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
If you are serious about dumping all of this money into the power adders, why not protect your investment and purchase a block that will handle the stress rather that throwing up a "Hail Mary" and praying that your block is up to it? Put your money into a good foundation first, then build the house.
Never fast enough.
Old May 1st, 2008, 09:56 PM   #31
Goblin's Avatar
Secret In The Works
Good advice.
Definition of Fast?
Old May 1st, 2008, 10:20 PM   #32
BUGMAN's Avatar
Hm... If your only wanting 500 rwhp then just build a 306 and throw an S trim on it. With a fair build (heads, etc.) you will hit 500 and if tuned properly it will hold fine.
I have several stock 302's all over 500 rwhp. For example my 94 Gt has a stock 302 block (306), Edelbrock heads (out of the box), main stud girdle and a few other minor mods with a junky old school Powerdyne (got it cheeeep) and it puts 459 to the rear tires. I have put 20,000 miles on this car in the past 2 years and it runs like any other DD on the road but with an awesome passing gear.
Now don't get me wrong I like N.O.S. just fine and use it on several of my cars but with the blower I just left it simple. If anything I may add a 50-75 shot to it just for some quick get up and go.
Good luck on your build.
You haven't failed until you stop trying.
Old May 1st, 2008, 10:41 PM   #33
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
if you are going to buy a block, h/c/i and stroker why not go with a 351 ???? you can stroke it to over 400 cubes just as easily as you can build a 347 , plus with the right h/c and intake you can make 500 hp WITHOUT a supercharger or nitrous and not worry about splitting your block , and it will be cheaper then your supercharged 347 build
Old May 2nd, 2008, 12:48 AM   #34
FoxHoss's Avatar
02' GT
+1000000000000
'02 GT~dd
Old May 2nd, 2008, 12:57 AM   #35
1965 Mustang Fastback
+a lot
Old May 2nd, 2008, 07:40 AM   #36
BUGMAN's Avatar
Agreed!
However a S/C 302 would be much more streetable than any N/A with 500 rwhp. JMO.
Old May 2nd, 2008, 06:17 PM   #37
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
Originally Posted by BUGMAN View Post
Agreed!
you can always build a very mild stroked 351 and supercharge that and it'll be very streetable, i was just trying to point out that if you are starting from scratch and have to buy everything it would be wiser to start with a 351 as opposed to a 302, now if you already have a bunch of hi po 302 parts ( intake , supercharger, long tubes and such ) then a 347 would be cheaper
Old May 2nd, 2008, 08:28 PM   #38
nolife's Avatar
I have roughly the same thing. 302, GT40x heads, old school Vortech and between 450 and 500 RW.
1991 GT - Original owner, all stock
1988 GT - The project car
Old May 2nd, 2008, 09:08 PM   #39
I've pretty much made my decision I'm going to buy a Super Pro Bullet 347 +6cc Twisted Wedge$3199.95
from dssracing.com
Get twisted wedge heads, nice size cam, and go carbed with NOS.
You guys think this will be a good setup. I just don't really want a 351, because I'm going to keep it street. Every once in awhile take it to the strip.
Old May 2nd, 2008, 09:39 PM   #40
its still a stock block
Threads Similar to: Will stock block hold up?
Is there a Block that can hold more HP than the stock 5.0L out there? The Novice 5.0 Mustangs 24 April 18th, 2008 10:25 AM
Stock Block GOTTORQ 2005+ 56 January 11th, 2008 06:05 PM
stock block Fast98stang 96-98 14 January 2nd, 2008 10:59 PM
How much power can a stock 05+ hold. powersrj 2005+ 22 June 13th, 2007 11:43 PM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 01:31 PM
