Discussing Will stock block hold up? in the 5.0 Mustangs Forum. Originally Posted by kratos2250 I've pretty much made my decision I'm going to ...
Old May 2nd, 2008, 11:59 PM   #41
BUGMAN's Avatar
Originally Posted by kratos2250 View Post
I've pretty much made my decision I'm going to buy a Super Pro Bullet 347 +6cc Twisted Wedge$3199.95
from dssracing.com
Get twisted wedge heads, nice size cam, and go carbed with NOS.
You guys think this will be a good setup. I just don't really want a 351, because I'm going to keep it street. Every once in awhile take it to the strip.
IMO your first mistake was "DSS" anything. Hope you have better luck than the many engines I know of that came from them.
You haven't failed until you stop trying.
Old May 3rd, 2008, 12:16 AM   #42
Alright you got me spooked. I'm going to waste 3 grand on a motor that's gonna blow up n me.
Old May 3rd, 2008, 12:20 AM   #43
ryans88gt's Avatar
DSS sells quality parts, I've visited there production facility a couple times. There are many people in the racing world that use there machining services too.
There factory blocks are not going to hold any more power than any other factory block, but they might produce a bit more power since they do a better job squaring the bores than the typical machine shop.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old May 3rd, 2008, 12:56 AM   #44
There's another one that I was looking at, it's the Pro Street 347 from coast high. It says it's rared up to 600 horse. Whats the difference in flat top, dish, and dome top pistons.
Old May 3rd, 2008, 02:22 AM   #45
BUGMAN's Avatar
We have all our machine work done locally now along with assembly that we don't have time to do here.
No negative bashing but I will say that our machine shop will warranty a bad wrist pin installation.
Where are you located?
Old May 3rd, 2008, 02:33 AM   #46
ft. walton beach FL
Old May 3rd, 2008, 02:40 AM   #47
1987 ford mustang gt
well see when shes done
they overate those blocks dont believe everything you read for one ive learned that over the past couple of years. It is still a stock block it just has a forged crank in it which is a waste of money in a factory 5.0 block.
Dish are also know as low compression pistons '' boosted motor''
flat top are just regular pistons i.e. they have a flat top and are used to acheive a moderate compression
dome pistons are just like they say they are domed to achieve a high compression ratio
Now of course pistons are not the only thing that affect c/r there are many factors, head gasket thickness, how far the piston is in the cylinder or if its zero decked,comb. chamber ect.....///
Old May 3rd, 2008, 09:29 AM   #48
BUGMAN's Avatar
ft. walton beach FL
Hm not too far. If you were a tad bit closer I would highly recommend Proline here in Ga. If the drive doesn't scare ya it would be well worth it.
I honestly think you would be better off in the long run finding someone close to you with a good reputation of engine building and have them build what you want. There should be plenty of reputable machine shops local to you so if you have any issues you don't have to deal with it by phone. Do you really wanna ship or drive your engine 3-5 states away if there are any problems with it?
Threads Similar to: Will stock block hold up?
Is there a Block that can hold more HP than the stock 5.0L out there? The Novice 5.0 Mustangs 24 April 18th, 2008 10:25 AM
Stock Block GOTTORQ 2005+ 56 January 11th, 2008 06:05 PM
stock block Fast98stang 96-98 14 January 2nd, 2008 10:59 PM
How much power can a stock 05+ hold. powersrj 2005+ 22 June 13th, 2007 11:43 PM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 01:31 PM
