Discussing Will stock block hold up? in the 5.0 Mustangs Forum. I have a 89 gt, and I'm bout to start my build. supercharger 8-...
Old April 30th, 2008, 10:16 PM   #1
supercharger 8-10psi
trickflow top end kit
rebuild my stock 302 block into a 347
100 shot of nos.
You guys think this will get me 500rwhp? Will my stock 302 block hold up to this much power.
Old April 30th, 2008, 10:19 PM   #2
fogged306's Avatar
89 GT
With a stock block, thats a grenade. Just depress the throttle to pull the pin.
If you want to do all that either go with an aftermarket block or an older model year 351
and if you do it right, that would be much more than 500rwhp.
Old April 30th, 2008, 10:22 PM   #3
nolife's Avatar
The stock block will will work great with that combination until it fails
1991 GT - Original owner, all stock
1988 GT - The project car
Old April 30th, 2008, 10:34 PM   #4
LOL I was afraid of that. Where can I get a bad ass block that can hold this bad ass combination? Or should I go with a 5-6 psi supercharger what would the diff be?
Old April 30th, 2008, 10:42 PM   #5
1987 ford mustang gt
well see when shes done
100 shot of nos.
ok the nitrous and blower thing is stupid as shit. you can make 500 rwhp with a blower alone. And the stock block will be a ticking time bomb that noone knows how long it will last maybe 1 run at the track and maybe 5 years we dont know.
If you want a badass block call up world products or dart. But they are not cheap both are about 2500 bucks. and how is this a badass combination you are buying a topend and throwing a s/c on it?
Without the nitrous and a 5-6 psi supercharger you will still be pushing the block 2 the limit.
Old April 30th, 2008, 10:51 PM   #6
Ok so what should I do? I want a 500 rwhp car, and I want a 347.
Old April 30th, 2008, 10:53 PM   #7
01 nitrous injected GT
12s next time out...
get a bulit block...and im pretty sure nitrous is sorta pointless with the s.c cuz you can just bump up the psi like 2-4 or something and get that extra 100rwhp you would with a 100 shot
Old April 30th, 2008, 10:54 PM   #8
too slow
ha
Chose one or the other...charger or nitrous. You might as well piece together a top end if you are throwing on a S/C instead spending the money for the FULL kit that you wont use all of. I def see the block failing if you try and throw all that at it.
95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete
Old April 30th, 2008, 10:55 PM   #9
2-4 psi is not going to net you anywhere near 100rwhp
Old April 30th, 2008, 10:56 PM   #10
then 8-10 lol
i dont know the numbers or anyhting, im just pretty sure you can increase the psi instead of using nitorus rite?
Old April 30th, 2008, 10:57 PM   #11
Why is 500rwhp the magic number? buy a dart or world products block or better yet call coast high performance and order a dominator series 363 short block. then put the topend of your choice on it.
Old April 30th, 2008, 10:58 PM   #12
then 8-10 lol
yes with diff pullies
Old April 30th, 2008, 10:59 PM   #13
i mean if he really wants cant he just get a stronger block and transmission and set it at like 25 psi and get like 800rwhp or something like that
Old April 30th, 2008, 11:04 PM   #14
Alot more goes into it than that but yes
Old April 30th, 2008, 11:07 PM   #15
like wat besides real end?
i know the TT kits i was looking at for like 7k some wiht the fuel pump and other stuff like that
Old April 30th, 2008, 11:15 PM   #16
The main reason to go with Nitrous and a blower at the same time is not a bad idea. Go with like a wet 75 shot. The reason for doing this is two fold. One-you are taking cold air and compressing it through the blower-we all know when you compress air it gets hotter than normal and then you are sending hot air into the intake. 2-it keeps you from having to run an intercooler/aftercooler and IMO can be more efficient. I am considering this because of that. It really isnt another power adder because all you are doing is cooling the air down when it reaches the combustion stage.
Also. How many miles are on the blcok? Was it modded at all. I know someone right now runnig 9.80's on a stock block with a 76mm turbo. Its a 306 so there is still plenty of block there. I would consider one thing. Your block may be worn down and if it is then you are taking a worn out block and seriously reducing the walls in the block to go with a 347. Go with a 331 if you want to do that.
Old April 30th, 2008, 11:16 PM   #17
You would haft to build a car to see what all goes into it. Theres alot of things that you would never dream of.
Old April 30th, 2008, 11:17 PM   #18
yea i heard about the cooling factor of using the nitrous but from wat ive heard you can just get an intercooler to not over heat nething
Old April 30th, 2008, 11:17 PM   #19
What is meant by peicing together a top end kit. I'll just forget about the nos. I'd rather have a s/c. This is kinda confusing. I know the TF top end kit will produce good power and I like to add a s/c to it. Then get a built 347, and call it a day.
Old April 30th, 2008, 11:19 PM   #20
Dont worry about overheating really. I have a V2 S Trim and it works great. The problem is that superchargers get heat soaked right at the motor and the intercooler is a good idea but does not work as well as Nitrous. Also you are compressing air so fast that it hats up at the supercharger so the intercooler becomes useless at that point. An aftercooler would be an idea though. I mean would be pretty efficient as well.
Threads Similar to: Will stock block hold up?
Is there a Block that can hold more HP than the stock 5.0L out there? The Novice 5.0 Mustangs 24 April 18th, 2008 11:25 AM
Stock Block GOTTORQ 2005+ 56 January 11th, 2008 07:05 PM
stock block Fast98stang 96-98 14 January 2nd, 2008 11:59 PM
How much power can a stock 05+ hold. powersrj 2005+ 22 June 14th, 2007 12:43 AM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 02:31 PM
