Discussing since I'm still new to Fords in the 5.0 Mustangs Forum. I was trying to find and figure out a couple of things, I don't ...
Old May 1st, 2008, 01:10 AM   #1
CUL8TER's Avatar
I was trying to find and figure out a couple of things, I don't know many 5.0
guys around my town, so I'm asking you guys for some answers
*1st I was trying to figure out how the mass air can tell what injectors you
are running (if its by OHM's, duty cycle, or ?)my mass air is still cali. for 19lbs
but I am going to install 30lbs inj., or if there is a way to fool the mass air
without changing the tube?
*2nd I was just wondering about is if there is any difference between the 93
to 95 GT/cobra heads to the later 90's GTP heads, I'm getting ready to help
a neighbor swap the broken 5.0 out of his Explorer and was going to swap
the heads for my bone stock ones before returning the core, and keep both
my GT's & the GTP's.
just let me know what you guys know
95 5.0 GT street/strip bruiser
Old May 1st, 2008, 06:48 AM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
p heads have smaller cc's, diffrent plug angles, smaller(but better flowing) exhaust valves.
you have to either re calibrate the electronics in the maf, computer, or sample tube to get diffrent inj. to work.
Old May 9th, 2008, 12:48 AM   #3
CUL8TER's Avatar
OK which heads do you think I should use, my GT heads have .040" shaved
off fo them allready to shrink up the cc's, or if the GTP's would be better, so
far the rest of my engine combo is or is going to be set up as followed
302 short block w/flat tops
E303 cam & springs
1.7 roller rockers
24lb. or 30lb. injectors
trick flow intakes
1 3/4" long tube headers and 3" X piped exhaust
75h.p. shot of laughy gas (if needed)
I do want to get a 70mm or 75mm throttle body
just installed a 3600 stall into the AODE, and set up the 8.8 with some 4.30
gears, mounted up the new 28" et streets
I had just missed out on a set twisted wedge heads this last weekend at our
local swap meet, but did pick up a mass air with extra tubes for 24/30 inj.
Old May 9th, 2008, 01:30 AM   #4
e3sean's Avatar
use the gtp heads have em worked a lil and that will be a desent improvement for a low cost. also get the intake manafold off of it and use that one.
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331
Originally Posted by ryans88gt View Post
'bout time to change that sig, isn't it sean? I mean speedy already left, came back, left again, and admitted he liked taking it in the rear.
Old May 9th, 2008, 01:36 AM   #5
Tony_90fox's Avatar
use the explorer top end, gt40p heads, and upper and lower intake...you can also mod the throttle body to work too.
as far as the mass air unit. What size is it now? if stock, you might want to consider going up to a 73-76mm MAF and get the 30# sample tube.
Suck on it Trebek. Suck it long, suck it hard.
Old May 9th, 2008, 05:37 PM   #6
Speedstang302's Avatar
1989 Mustang LX 5.0
12.86@ 111mph
yeah cuz the stock explorer tb is 65mm...
1989 Mustang LX 5.0
Stock w/ F303 cam and 1.6 Roller Rockers
BBK Shortys, BBK o/r H, Flowmaster Super 44s
"The LS1 was subject to a paternity test!!! The results are back....03 cobra you are the Father!!!!"
Old May 9th, 2008, 07:07 PM   #7
lineumup88's Avatar
you will need different headers to run the p heads though or else you will burn up plug boots. they are kinda high in price.
hey chevy boy.....i got something for you to POWERSTROKE!
Warning: surgeon general says its ok to smoke ricers!
Threads Similar to: since I'm still new to Fords
Fords At Englishtown NJ Stangzilla The Clubhouse 2 November 3rd, 2007 03:01 PM
Fords At Englishtown NJ Stangzilla Northeast 1 November 3rd, 2007 12:18 PM
Do you like Fords? 96Snaker Pictures 17 August 14th, 2007 02:23 PM
fords v6smoker V6 Mustangs 28 December 10th, 2006 04:17 AM
Info for those of you who own 96-02 fords. stangliter04 96-98 0 August 22nd, 2005 05:23 PM
