![]() iTrader: 1 reviews
Help Intake Manifold
I am getting an upper and lower intake manifold, but not sure which to get. here's my option, you guys tell me which is best. I have to do EGR.
1. Holley Systemax II Ford 5.0L EFI Manifolds (upper & lower) 2. Performer 5.0, Intake Manifold (Edelbrock w/Intake Manifold Base) Cylinder Heads: I should get Complete Assembly? but.... what does it comes with complete. if you know or can link me to a site that have a complete HCI, kit to work with either of the upper and lower intake, please let me know. thanks ------------------------------------------------- 94 GT 70MM TB BBK CAI BBK Shorty Headers Off Road x-pipe Flowmaster |
The Systemax is a nice intake. Alot of guys are making good numbers with that intake. Complete heads would be the way to go. You just have to make sure the valve springs will work with the cam you choose. If you are using a stock bottom end go with the Trick Flow twisted wedge heads. They are the only head out there that runs a 2.02 intake valve that most of the time doesn't have any valve to piston clearance issues with stock pistons. They also come in CNC ported versions with either a 185cc runner or a 205cc runner. A fool proof combination is a set of twisted wedge heads, Trick Flow part number 5142001 cam and either the Holley Systemax intake or a Trick Flow Track Heat intake. That set up will make around 310 or so horsepower at the wheels thru a manual transmission.
Sorry I missed the cam. I am also doing the cam. This car is a summer drive car. I dont want a rought idle but a decent cam. I am also doing a turbo down the line. So I'll have to get a set of complete heads, I actually was thinking the heads from Holley also.
Holley Heads: Small Block Ford Cylinder Head Valve Angle: 17º Intake Runner Volume: 165cc Combustion Chamber Volume: 63cc Intake Valve Diameter: 1.90" Exhaust Valve Diameter: 1.60" Pedestal Rocker Mounts Maximum lift: .600" and also a cam from jegs. (or if there's a better from from there. I actually got $3500 to spent, its a gift card for jegs.com so all parts has to be from there. I was also thinking the system max. I'll do that. But I'm new at this and dont want to get a set a heads and cam and down the line have to change it when I get a turbo. If you can find a better one that the Holley on jegs.com dude i'll really appericate it. and also thinking about the B CAM (397-M-6250-B303K) I am heading for a goal of 350 rwhp for now. 310 sounds pretty good for the setup, anything else that I can add to bump it up alittle? Thanks alot. |
Yeah it is a manual tranny, recently did the clutch, Center Force Dual Friction
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
#5 | |
OK, so here's what I'm Doing:
Intake: Holley Upper and Lower Intake. Part: 510-108-80 Heads: Small Block Ford Cylinder Head Valve Angle: 17º Intake Runner Volume: 165cc Combustion Chamber Volume: 63cc Intake Valve Diameter: 1.90" Exhaust Valve Diameter: 1.60" ARP® Rocker Studs Maximum lift: .600" Part: 510-300-573 Cam: Xtreme Energy XE274HR Hydraulic Roller Camshaft Only Lift: .555''/.565'' Duration: 274°/282° RPM Range: 2200-6200 Thats the HCI complete. OK, That sounds good, and do I need anything else. I"m also doing the Timing chain and cover I got that already. (if i am not mistaking, its a double chain?) So Please before I go and order this, Do i got everything I need here? and of course all the gasket/s to go with that good stuff. Dude thanks alot man, I really appericate your help on this. |
Head, intake, valve cover, timing chain and header gaskets will be needed. New head bolts, do yourself a favor and get ARP bolts. Get a good timing set, not a local auto parts store stock replacement. You will most likely need roller rockers with those heads and will have to find out if the stud size is 3/8 or 7/16. The customer service rep can help you with everything you need.
How about this for the gasket set:
jegs part#: 720-4410 Includes two valve cover gaskets, intake gasket set, oil pan gasket set, water pump gasket set, timing chain cover gasket, and a fuel pump gasket |
and i'll find out about the rollor rockers later, and let you know.
Thanks alot man.
Threads Similar to: Help Intake Manifold
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 21st, 2010 12:20 AM |
| Intake Manifold. | Slicey | 99-04 | 10 | January 13th, 2008 05:50 PM |
| need a intake manifold | matfernan1 | 99-04 | 22 | September 28th, 2007 12:54 AM |
| BBK Intake Manifold | lugthug713 | 94-95 | 13 | October 31st, 2006 11:06 PM |
